lmoss30
Camara Rate On Stills
Mon May 20, 2013 10:41 am
Morning All,
Just received camera module, was wondering what the quickest rate of taking photos are in stills mode is?
Lee
poing
Re: Camara Rate On Stills
Mon May 20, 2013 11:04 am
I think you should experiment with the timelapse option. The normal mode uses something like 0.5 sec to work out exposure and WB.
maddogdave
Mon May 20, 2013 1:38 pm
The time lapse mode worked for me at 0.5s intervals, although I would probably use 5, 10 or 15 seconds as a 'normal' interval depending on what I was trying to capture. Trying too fast a time will result in errors popping up ('unable to return a buffer to the encoder port' and 'unable to get a required buffer 0 from pool queue') is what I got displayed (@100ms). I would stay safe and probably use 1 second to give the device time to capture and write / save the file. If you need a faster capture rate then extracting frames from a video file is probably the best option.
Dave
Return to “Camera board”
