oystercatcher
raspivid crashes network?
Sun May 19, 2013 9:34 pm
I just got my camera module a couple of days ago and I am having a problem with the
software commands either raspivid or raspistill
I think preview might be part of the problem and I read that the source can be
recompiled to turn off preview. When I try to pass -n the commands fail.
If I am logged into the pi via ssh and run either of the commands the network stack
crashes and the ethernet port loses its ip address. I may try shortly to hard code an
ip address as I am using dhcp for the pi.
If I run raspivid or raspistill from the console I can see the preview and the command
completes but the network goes down anyway.
Just looking for some ideas on what to do next?
patrick in socal
poing
Re: raspivid crashes network?
Sun May 19, 2013 9:38 pm
Maybe power issue; the camera draws around 280mA. Others mentioned the Pi crashes or reboots when they activate the camera due to power.
condew
Mon May 20, 2013 3:54 am
I saw the same symptom. I was powering my pi from the USB port on my monitor to the micro-usb power input on the pi. While playing with the new camera, I went to check raspberrypi.org for more information and the browser could not find it, nor anything else. I found a simple sequence to reproduce the problem; "ifconfig" to show my network had an ip address, "raspistill" to capture an image, and then "ifconfig" to show my ethernet no longer had an ip address.
I switched to powering the pi vi a hub that backfeeds power thru one of the usb ports and has a beefier power supply that says it produces in excess of 3 amps.
With the new power source, the ifconfig, raspistill, ifconfig sequence worked. Network access was confirmed by viewing the raspberrypi.org site after the image capture.
So I concur, camera use crashing the network connection is probably a power problem.
oystercatcher
Mon May 20, 2013 10:37 pm
thanks for the input on power being the culprit.
Today I have a small powered hub from gear head model UH5500ESP
raspistill is now working via a bash shell loop
#!/bin/bash
PIS=/usr/bin/raspistill
SAVEDIR=/home/pi/tmp
PARM01=" -w 640 -h 480 "
for i in `seq  1  20`;
do
OFILE=$SAVEDIR/$filename
$PIS  -vf  -t 0   $PARM01 -o $OFILE
sleep 5
done
My original AC charger is a cirago
model ZXT138B-2.0 1 A output
but unfortunately not up to the task with the camera module installed.
Void
Wed Aug 14, 2013 2:52 pm
Hi, I just had the exact same problem. Using raspivid killed the pi's network. So I connected it with a USB to my laptop which in theory outputs more power then my adapter and problem solved ! :)
Return to “Camera board”
