FleaBit
How's this thing work?
Sun May 19, 2013 1:33 pm
After fighting memory card brand related issues to get this camera working, once I have it working, I'm stuck. I can type the commands and get a flash of a preview on the screen, but what's actually happening? Is it actually capturing video or jpegs and storing them somewhere? If so, where? Or, are raspivid and raspistill just tools to be used by something else to actually capture it, meaning you have to write code to make something actually capture? Or do those commands capture it. If so, where's the magic storage place (I can't see any directories listed in that area where those commands are)?
I got to this party late, so forgive me. I have exactly 1 day of exposure to it. I've searched a searched but haven't found anything that actually shows you taking stills. Lots of streaming instructions, but I can't find much on stills.
Is there a guide for taking stills, where they are stored, how it all works, or am I completely missing something obvious (which is HIGHLY possible).
Thanks for putting up with my basic questions!
Oh, let's just add a scenario in case that helps- I'd like to capture stills at will.
fbutler
Re: How's this thing work?
Sun May 19, 2013 1:39 pm
FleaBit wrote:After fighting memory card brand related issues to get this camera working, once I have it working, I'm stuck. I can type the commands and get a flash of a preview on the screen, but what's actually happening? Is it actually capturing video or jpegs and storing them somewhere? If so, where? Or, are raspivid and raspistill just tools to be used by something else to actually capture it, meaning you have to write code to make something actually capture? Or do those commands capture it. If so, where's the magic storage place (I can't see any directories listed in that area where those commands are)?
The basic instructions are in this post:
http://www.raspberrypi.org/archives/3890
To see a full list of options for the raspistill program use the command:
raspistill | less
FleaBit
Sun May 19, 2013 2:07 pm
Thanks, I'd seen all of that and was still missing something. In rereading it, I think I had the lightbulb moment finally. Some days the light comes on quicker than others!
Thanks!
FleaBit
Sun May 19, 2013 8:45 pm
Okay, apparently the lightbulb that came on burned out quickly.
When I type the following in :
I get the following error message :
"mmal: main: Error opening output file: image.jpg
No output file will be generated"
I'm not sure how I'm capable of taking something so simple and making it so complicated, but apparently I have a talent for it :)
DirkS
Sun May 19, 2013 9:00 pm
Do you have write permission for the location the file is written to?
Gr.
Dirk.
FleaBit
Sun May 19, 2013 10:47 pm
That's a good question and part of my original question. Where's it writing to?
It's a bone stock, fresh install of the OS, with nothing else done other than installing the camera. I've followed the exact examples in the documentation and that's the errors I'm running into. I'm surprised I'm the only one to see it, since I've modified nothing.
DirkS
Sun May 19, 2013 11:10 pm
Current working directory. If you've just logged in with user Pi that will be /home/pi and if you issue the raspistill command from there it should not give any permission problems.
Gr.
Dirk.
FleaBit
Mon May 20, 2013 12:18 am
I did that and got the same error. I chmod'ed it and now it all seems to work fine.
Thanks for the help. Hopefully my questioning on this part is over, as it looks like I have taken several photos and confirmed their location and quality.
Thanks for the help, I appreciate it!
GardenSteamer
Mon May 20, 2013 4:36 am
I had the same problem and solved it with
fbutler
Mon May 20, 2013 7:17 am
GardenSteamer wrote:I had the same problem and solved it with
You shouldn't need to run the camera commands as root. It looks like there are permission errors due to where you are in the directory structure when you run the command. You must have write permissions to the directory where you are creating the image.jpg file.
Pshock13
Tue Aug 11, 2015 3:58 am
fbutler wrote:You must have write permissions to the directory where you are creating the image.jpg file.
I'm have trouble writing to '/mnt/picam' a directory that I created. As in ...
raspistill -o /mnt/picam/test.jpg
I get this error
mmal: main: Error opening output file: /mnt/picam/test.jpg~
How do I go about checking the permissions of /mnt/picam?
how do i change the permissions?
and how do I know what permissions to change them to?
JimmyN
Tue Aug 11, 2015 3:25 pm
You should have created a new thread for your question rather than adding to an old one. But since you're here....
You created a mount point /mnt/picam. The permissions and ownership for /picam will be determined by the mount command you used when mounting the drive to /mnt/picam. What type of filesystem is the mounted drive using? If it's FAT32 or NTFS they don't supply any credentials so ownership and permissions have to be specified in the mount command. If not specified the default would be root as the owner of everything in /picam.
If it's an ext* filesystem you can use the "chown" command on the mounted drive (/picam) if you need to change the ownership.
You can see the ownership and permissions for the mounted drive by using:
ls -l /mnt
If ls -l shows something like
drwxr-xr-x 2 root root 4096 Jan  9  2015 picam
then the mounted drives files (picam) belong to root and you'll need to use 'sudo' to write to it. If it looks more like
drwxr-xr-x 2 pi pi 4096 Jan  9  2015 picam
then the files belong to 'pi' and you're all set.
Return to “Camera board”
