nickneubrand
Raspivid Pygame Stream
Sun May 19, 2013 5:43 am
Hey,
Does anyone know what the camera is labeled, when regarding its device name. When you use code in pygame to access a camera you use:
cam = pygame.camera.Camera("/dev/video0", (640,480))
The problem is /dev/video0 doesn't work. Is there another label that I can use to get a video stream. Keep in mind I am not using a network. I just want a window to pop up(which I already have) and show me what the camera is pointed at. Any help would be appreciated.
I have heard OpenCV might work but I would like to run it via python/pygame if possible
recantha2
Contact: Website Facebook Twitter
Re: Raspivid Pygame Stream
Sun May 19, 2013 7:25 am
The camera is not mounted in that way. Someone is looking at writing drivers so that it _can_ be mounted, but it's likely to be months away.
Michael Horne - @recantha
Raspberry Pi blog - http://www.recantha.co.uk/blog
Cambridge Raspberry Jam
Website: http://camjam.me
Facebook: https://www.facebook.com/cambridgeraspberryjam
Follow the Cambridge Raspberry Jam on Twitter - @cambridgejam
nickneubrand
Sun May 19, 2013 8:21 am
damn, thats upsetting
ghans
Sun May 19, 2013 8:26 am
Get creative , maybe a pipe can solve your problem (popen etc.)
ghans
nickneubrand
Sun May 19, 2013 8:27 am
im completely new to raspberry pi so i have no idea what a "pipe" is
ghans
Sun May 19, 2013 8:53 am
http://www.tuxfiles.org/linuxhelp/iodirection.html
After that , have a look into "Named Pipes" and/or
Pythons os.* and Subprocess modules.
ghans
nickneubrand
Sun May 19, 2013 9:15 am
Thanks for the reply, I get the concept, but honesty I think this is way out of my range of capability. I'll continue to look at it, but for my low level knowledge on linux I don't think this is going to be a viable option for me.
ghans
Sun May 19, 2013 9:58 am
Hey , the Raspi is a learning tool.
If you did learn programming at some point , you should be
able to grasp the command line.
Lots of tutorials are online , here one which i've found via Google
http://cli.learncodethehardway.org/book/
ghans
Return to “Camera board”
