JamesRonald
Using raspivid with mjpg-streamer
Sat May 18, 2013 6:53 pm
Any ideas as to how I can use raspivid with mjpg-streamer or something similar to stream video from webpage. I am also using WebIOPi if there is anything in there that would be helpful.
Here's the typical html that I use to display the video stream from the RPi using mjpg-streamer and a attached USB webcam.
<img width="640" height="480" src="http://raspberrypi.local:8001/?action=stream">
I have a played with the following and it works great. However I need to view the video in a web browser.
# on the RPi
raspivid -w 640 -h 480 -fps 30 -t 999999 -o - | nc 192.168.1.129 5001
# On my Linux host
nc -l 5001 | mplayer -fps 40 -cache 1024 -
James Ronald
martin.c.webb
Re: Using raspivid with mjpg-streamer
Sat Jun 15, 2013 9:03 am
Probably too late for OP - but this will help anyone else:
http://blog.miguelgrinberg.com/post/str ... nd-android
JamesRonald
Sat Jun 15, 2013 2:54 pm
That's what I ended up doing as an interim solution. I can only get about 10FPS to work in a some what reliable fashion. I'm hoping the someone will add a http server option to raspivid or a raspivid type plug-in for mjpg-streamer. Using the mjpg-streamer http server as an example, I figure that I would be about 10 of hours of work to get something working.
renelm
Fri Mar 07, 2014 4:19 pm
I too have a USBattached webcam and got curious as how to use raspivid and raspistill with a webcam, since both commands rely on the optional camera module?
All I get when running raspivid and raspistill is :
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
Can't really find any more info on this as most posters on this actually do use the the optional camera module..
ghans
Fri Mar 07, 2014 5:23 pm
The official camera apps are of zero use without the official
camera ... normal webcams are mostly exposed via the
popular V4L2 / V4L APIs , which many applications support
already and readily use (esp. motion or mjpg-streamer) - the
Pi camera is directly connected to the GPU and uses a
Broadcom-specific way of access.
Because of that , the foundation has released a V4L2 driver for
the official camera. It should make the camera availible to any
V4L2 - compatible application , just like regular webcams.
Which might be useful for anybody who actually has the
same problem as the first poster , i guess the goal is to get
more performance out of it than 10 fps via
timelapse / temporary file workarounds.
http://www.raspberrypi.org/phpBB3/viewt ... 43&t=62364
ghans
Return to “Camera board”
