Videostream etc over the internet
Posted: Fri May 17, 2013 3:38 pm
by SN
Not seen this (to be fair not looked too hard
Assuming I have apache2 install on my raspi and all the ports open on my router to the internet, is there a straightforward way to make this work - I'm thinking mjpeg or similar with a 1 or 2 second framerate?
Re: Videostream etc over the internet
Posted: Fri May 17, 2013 4:37 pm
by nicknml
I'm also interested in doing the same thing. I did something similar with a USB cam in the past but it didn't work very well. I used something other than Apache.
On a side note, I almost killed my Pi and camera module in a clutz moment when the camera module made contact with the GPIO for a split second. The Pi rebooted itself and everything appears to be working ok.
Posted: Fri May 17, 2013 6:11 pm
by alexeames
nicknml wrote:I'm also interested in doing the same thing. I did something similar with a USB cam in the past but it didn't work very well. I used something other than Apache.
AH. You found the 'spare reset switch'
Posted: Fri May 17, 2013 8:21 pm
by pippo
Heyho, i use raspistill for this with some javascript. You will need php, sudo and an Apache webserver.
raspistill.php
<?php
passthru("sudo raspistill -t 0 -o - -w 800 -h 500 -e jpg -q 70 -ex auto");
visudo:
www-data ALL=(ALL) NOPASSWD: /usr/bin/raspistill
Then you take the source of
mjpegstreamer and edit the file
javascript_simple.html and copy it to
/var/www:
img.src = "raspistill.php?n=" + (++imageNr);
Then check the picture with a nice framerate at:
http://pi/javascript_simple.html
Posted: Sat May 18, 2013 2:38 pm
by fin
That solution (javascript) worked for me temporarily, but it kills the camera (requires a reboot to work again) after a few minutes - any idea what's up?
Posted: Sat May 18, 2013 4:49 pm
by fin
Nevermind, I'm actually getting an error from the command line
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
Which might be related to GPU memory?
Posted: Sat May 18, 2013 5:23 pm
by ludespeedny
try switching the cable around and/or reseating it. That is what I did. I have another thread with the way the cable goes in
Posted: Sat May 18, 2013 6:40 pm
by towolf
See the thread here:
http://www.raspberrypi.org/phpBB3/viewt ... 4&p=351398
This is your best bet for streaming video over the internet. It chops the video stream into short segments and drops them into the www directory. A spearate .m3u8 playlist announces the currently valid segments and the player hops from one segment to the next without interruption.
This is knows as HTTP Live streaming and is an Apple Computer standard. So far support is built into i{Phone,Pad} and newer Android devices. I found VLC and FFMpeg and Gstreamer can play as well.
Drawback is, it is delayed by the length of one or two segments (e.g. 10-60 seconds).
Posted: Sat May 18, 2013 7:06 pm
by audioscience
Posted: Sat May 18, 2013 7:40 pm
by towolf
audioscience wrote:Why not just use MJPG-Streamer?
Why low fps MJPG when you can have fast fps H264?
Posted: Sat May 18, 2013 7:42 pm
by alexeames
Nice
Is that using a RasPiCam?
Did you compile it on the Pi yourself or is it in the repo?
Posted: Sat May 18, 2013 9:26 pm
by audioscience
No Raspi cam, it's a Logitech HD C310 webcam. Costs $30. No additional power needed (I use a 2 amp power supply, no USB hub with USB Wifi dongle plugged in).
Compiled on the RasPi. Follow these instructions:
http://www.raspberrypi.org/phpBB3/viewt ... 39#p164539
