Andybp
streaming to mplayer on mac
Fri May 17, 2013 3:33 pm
hi all....
So camera turned up today, installed hardware, updated software. All great.
Apart from the link in the instructions to mplayer. This points to a powerpc version of mplayer. this wont work on my machine which is a new one ( I think all machines in the last few years wont work with this?)
I do have vlc installed though. does anyone know if I can stream to this?
I have taken pictures with the cam, and created videos etc.
Its just this final piece of the picture before I have the world most complex baby monitor.
Any help really appreciated.
P.s. the video and picture quality is way in excess of what i expected !!
jarrah31
Re: streaming to mplayer on mac
Fri May 17, 2013 8:54 pm
I used brew to download mplayer, and then seeing as the Mac streaming instructions aren't correct for the nc command, I used the following:
nc -l 5001 | mplayer -fps 31 -cache 1024 -
It all worked a treat on my MacBook Air 2012
gregor
Sat May 18, 2013 3:27 am
Thank you! I was just coming here to look for some help!
rhubub
Sat May 18, 2013 9:43 am
What is brew and how does one use it to download mplayer?
I tried searching but didn't find anything to point me in the right direction, I'd be very grateful if anyone could help.
Many thanks.
Andybp
Sat May 18, 2013 10:04 am
its on the webpage.
go the the brew website at : http://mxcl.github.io/homebrew/
there you will see that it tells you to run the following command in your mac terminal :
ruby -e "$(curl -fsSL https://raw.github.com/mxcl/homebrew/go)"
when its installed (it took a while on my machine)
type: brew install mplayer
thats it. easy
I still havent managed to get mplayer to talk with my raspi though
Andybp
Sat May 18, 2013 12:33 pm
ok so now mplayer seems to have installed, and ive followed all the instructions.
The raspberry pi appears to be streaming (I.e. the light comes on), but I dont think data is coming through. Ive turned off the firewall on my mac, and still no joy.
after a little while, the raspberry pi just hangs.
Im not sre what to do now. I checked the voltage acros tp1 and tp2, and its reporting 4.88 v which is within tolerance it think.
Any advice welcome
Return to “Camera board”
