Default still image size is not using the whole sensor
Posted: Fri May 17, 2013 11:15 am
by poing
The horizontal field of view of a default still image is narrower than the default video. I experimented a bit and found the following:
The default width is set to 2592 pixels which gives an image that is more square than the video which is shot in 16:9. The height of the default image is 1944 pixels, so
1944 * 16 / 9 = 3456 pixels. Indeed, if I give the command:
 raspistill -hf -o image3456.jpg -w 3456
I get an image which is wider while retaining the same height. If I increase the number above 3456 the image becomes larger while retaining the horizontal field of view but it becomes more zoomed in vertically as you can see in the last image. Not sure why that happens.
Default image - width is 2592 pixels
width is 3456 pixels
width is 5000
Just so you know ;)
Re: Default still image size is not using the whole sensor
Posted: Fri May 17, 2013 1:15 pm
by kaos
Sounds like the default output is 4:3, which is the old school non-widescreen TV/video standard, and also used by some still cameras (e.g. the four-thirds and micro-four-thirds systems used by Olympus and Panasonic). The sensor, however, seems to be 16:9 widescreen, so you can increase the aspect ratio to that point without loosing any vertical resolution. Go any further and the camera will start discarding information top and bottom to achieve the asked for aspect ratio, and as a result zooming in.
This means that to take full advantage of the sensor's resolution, you should use it's native aspect ratio, 16:9.
Kári
Posted: Fri May 17, 2013 2:33 pm
by psergiu
You just found RPi's "uncrop" function. :lol:
http://www.youtube.com/watch?v=KUFkb0d1kbU
Posted: Fri May 17, 2013 5:39 pm
by jbeale
kaos wrote:The sensor, however, seems to be 16:9 widescreen, so you can increase the aspect ratio to that point without loosing any vertical resolution. Go any further and the camera will start discarding information top and bottom to achieve the asked for aspect ratio, and as a result zooming in.
There is something wrong here, because the sensor aspect ratio is not native 16:9 (1.778:1 ) it is much more square than that. The imaging area is 3.67 x 2.74 mm and each of the 2592 x 1944 pixels is square (1.4 x 1.4 um). That gives a full sensor aspect ratio of 1.342:1 which is approximately a 4:3 aspect.
I have a suspicion that the provided software is always using the sensor in 1920x1080 video mode even when capturing stills, and then upscaling or rescaling, instead of using the full native sensor resolution for stills.
From OV5647 chip specs at http://www.ovt.com/download_document.ph ... ensorid=66
RPi camera sensor image area: 3.6736 x 2.7384 mm and diagonal: 4.582 mm
Number of effective pixels 2592 x 1944 (Total: 5038848 )
Pixel pitch in µm: 1.4 x 1.4
Posted: Fri May 17, 2013 6:19 pm
by poing
Good find and thinking!
My camera is back to 'hospital' so I can't check. Besides the *cough* 'lens' *cough* is not really 'up to my standards', so to speak (although nicely cheap), so I think it's hard to find evidence of upscaling. But it's a very good point, when I get another camera I'll investigate.
Posted: Fri May 17, 2013 6:23 pm
by jbeale
You are right, there are no tack-sharp full-resolution images from the R-Pi camera just due to the lens, but here is what started me wondering about upscaling: http://www.raspberrypi.org/phpBB3/viewt ... 50#p329599
what else would you suppose would cause that non-integer-pixel "jaggy" aliasing on the edge of the flourescent light bulb, which in reality I presume does not have stair-step edges?
...actually, I suppose it could be complicated by the fact the fluorescent light is flickering due to AC power cycle, I don't know whether all pixels are exposed simultaneously, so to remove that doubt it would be better to have a test image with a non-flickering light source.
Posted: Fri May 17, 2013 6:45 pm
by jamesh
Hmmm, that sounds possible. I'll take a look on Monday. It may well be choosing the wrong mode at some point That code is rather complex and buried in the firmware, so its not possible to work it out from the Arm side.
The tuning we (well, David) did didn't use the same configuration of hardware, so this may have been missed, or something changed to mean the wrong mode is selected.
Posted: Fri May 17, 2013 6:53 pm
by jbeale
Thanks for having a look James. If it does turn out to be currently locked in 1080p mode, that means we might be able to enjoy (slightly) better resolution in true stills mode!
Posted: Fri May 17, 2013 7:03 pm
by jamesh
jbeale wrote:Thanks for having a look James. If it does turn out to be currently locked in 1080p mode, that means we might be able to enjoy (slightly) better resolution in true stills mode!
Actually should be quite noticeable better I would think. (1920x1080 vs 2592x1944)
Posted: Fri May 17, 2013 7:17 pm
by poing
If the 'lens' permits, otherwise it's just wasting bandwidth ;) But it should be investigated!
Posted: Sat May 18, 2013 7:20 am
by gkreidl
@james:
You should also check, if the cropped image may be the result of the lens correction algorithm. Basically a lens correction is a projection onto a curved surface. The resulting image may get larger this way; if the algorithm crops it instead of rescaling it to the original image size, that would explain the smaller image area. But quality of the image might be even better, if it is not rescaled but sent out with this "higher" resolution (make it into a feature).
Posted: Sat May 18, 2013 9:12 am
by jamesh
It's almost certainly picking the wrong camera mode (annoying as there are only two currently in there...). We don't do lens correction (well, we do lens shading correction but that is something different).
Posted: Sat May 18, 2013 11:11 am
by kaos
Ah, I was going entirely by the behaviour and didn't even think to check the actual sensor spec. :oops:
Kári
Posted: Sun May 19, 2013 11:36 am
by wallarug
psergiu wrote:You just found RPi's "uncrop" function. :lol:
Great Find! :D
Posted: Tue May 21, 2013 2:34 pm
by baz069
Nice find poing, the difference is amazing!
Posted: Tue May 21, 2013 6:27 pm
by jbeale
In case you haven't heard the latest- JamesH has confirmed that both 1080p video mode and every resolution in stills-mode is taking a 1920x1080 center-crop of the full 2592x1944 sensor, and rescaling / upscaling as necessary. No one (here) has yet seen a true full-sensor image from the R-Pi camera. Work is in progress to fix this. http://www.raspberrypi.org/phpBB3/viewt ... 31#p353815
Posted: Wed May 29, 2013 12:38 pm
by wallarug
Jamesh informed here that it has been fixed as of last Friday:
http://www.raspberrypi.org/phpBB3/viewt ... 2&e=359042
