RaTTuS
Raspivid FPS
Fri May 17, 2013 9:00 am
I know you know about it but I thought a separate topic would be good....
using
raspivid -hf -fps 1 -t 3600000 -o test.h264
I do get 1fps but the initial frames are black then it scales though the greens for a few frames until it settles down...
will you be able to make the fps go below 1 ?
1/min ? 1/hr
and how will you express this on the command line?
Covfefe
RaTTuS
Re: Raspivid FPS
Fri May 17, 2013 9:33 am
Askully ....
after a while of recording it goes into black then fade up though green .,... [15 mins or so ] I will check when it finished this 100min session.
so back to 2fps for the long view....
Covfefe
mikerr
Re: Raspivid FPS
Fri May 17, 2013 11:06 am
For much lower frame rates like that, it might be better by using raspistill timelapse ? (and higher quality)
e.g. 1 per second for an hour:
Of course then you have to encode them into a video.
There's a script here to do that here
http://www.raspberrypi.org/phpBB3/viewt ... 7&p=207503
but that's not accelerated.
Re: Raspivid FPS
Fri May 17, 2013 3:24 pm
The mode used for video is defined down to 1fps, but I've never got that working properly - 2fps was the best I could do. I think there may be a technical reason in the encoder (rather than camera) why lower than 1fps isn't possible, but it's on my list of stuff to check.
FlashT
Re: Raspivid FPS
Thu Jul 30, 2015 7:02 pm
for 1 fps you need to setup proper keyframes...
Return to “Camera board”
