Has anyone tried bitwizard's kit with a pibow case ?
Does the pi side board and cable fit in the case ?
ExactlyBurngate wrote:You can buy ribbon cable almost as long as you like - 50m on a drum, though the signal might not crawl that far - and it's easy to cut the length you want and put connectors on.
Using FPC ribbon, dressing the ends could be problematical.
I've not heard of anyone successfully doing this - not actually sure how you could do it. Maybe if you could source the cable connectors on the PCB and end of cable, and make you own tiny PCB as an extender.objekt wrote:Can someone tell me if it is possible to separate the camera module and extend the micro-ribbon cable? I want to build the camera into something where there is too little room for the board
Hi rew,sharix wrote:Woohoo!rew wrote:We've tested about 4m. Works fine.![]()
Pictures coming soon.
What type of cable did you use?
I have a picamera noir with a led panel, I need to put the cam at 1 meter from the raspberry. I can use this cable 1m long? I would have problems?mikerr wrote:20cm @ cpc /farnell - £1.20
http://cpc.farnell.com/jsp/search/produ ... ku=SC13281
30cm @ cp/farnell - £1.40
http://cpc.farnell.com/jsp/search/produ ... ku=SC13282
Not sure about the stuff from Farnell's, but when my 1m cable arrives from the UK ebay seller I'll test it and let you know.gara93 wrote:I have a picamera noir with a led panel, I need to put the cam at 1 meter from the raspberry. I can use this cable 1m long? I would have problems?mikerr wrote:20cm @ cpc /farnell - £1.20
Thanks a lot
