rew
Re: Alternatives or replacements for camera flex cable?
Mon Jun 03, 2013 12:05 pm
We've tested about 4m. Works fine. :-)
Pictures coming soon.
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
rew
Mon Jun 03, 2013 12:44 pm
Here is a picture that my raspberry pi camera took of it's own cable and raspberry pi....
sharix
Mon Jun 03, 2013 2:37 pm
rew wrote:We've tested about 4m. Works fine. :-)
Woohoo! :D
What type of cable did you use?
smx
Mon Jun 03, 2013 4:46 pm
rew wrote:Here is a picture that my raspberry pi camera took of it's own cable and raspberry pi....
This is exactly what I am going for. Please describe your setup and product models.
Mon Jun 03, 2013 6:37 pm
I am completely amazed that that works. Are the images particularly noisy compared to the short cable?
Working in the Application's Team.
markus3141
Mon Jun 03, 2013 6:54 pm
I'm wondering whether you are getting frame drops or errors with such a long cable.. USB always has some problems with such long cables and they aren't that high speed, are they?
rew
Tue Jun 04, 2013 10:09 am
Just a standard ribbon cable. We have a small webshop, and one of the items that doesn't sell much is the 20p ribbon cable with connectors. So we had 4m of bare ribbon cable as "stock" for say up to 20 cables of 20cm. But in this experiment we decided to just pinch a connector on each end and use that....
We improvised the "conversion boards" this time. But within two weeks we'll have the less-improvised boards available. If you want a set (with matching 16p cable) let us know.... (info at bitwizard dot nl)...
TarjeiB
Tue Jun 04, 2013 10:35 am
This will be alpha and omega for my solar webcam-setup. Hope it shows up in the webshop soon!
cjsm74x
Tue Jun 04, 2013 11:43 pm
jamesh wrote:I am completely amazed that that works. Are the images particularly noisy compared to the short cable?
Well. if it sounds to good to be true...
towolf
Wed Jun 05, 2013 2:58 am
What’s your point? to be sure, the black part under the green part is the connector.
cjsm74x
Wed Jun 05, 2013 3:52 am
OK,my mistake. I was under the impression that it was the backside of a camera board.
sharix
Wed Jun 12, 2013 10:00 am
Any news on the cables?
RaTTuS
Contact: Twitter YouTube
Wed Jun 12, 2013 10:04 am
I'd me more concerned for the RPi running on a carpet.
Covfefe
TommyboyNL
Fri Jun 14, 2013 1:32 pm
The adapter PCBs are in, but we're still waiting on a batch of FPC cables. We expect them to arrive early next week (hopefully monday).
You can already order the board at http://www.bitwizard.nl/catalog/product ... cts_id=146
Don't forget to also order the length of ribbon cable you want: http://www.bitwizard.nl/catalog/product ... cts_id=148
Pictures and documentation will be uploaded ASAP, I'm working on it as we speak.
mlaporta
Sun Jun 16, 2013 9:41 pm
Hi Folks,
I'm Michele and I'm at my first post in this forum. I'm also interested in this post. Long cable camera it's really useful expecially outside 8-)
Woohoo! :D
I think is this anyone that can confirm?
Michele
mikerr
Sun Jun 16, 2013 10:11 pm
HAve you tested that PCB/cable with a longer (10min+) video capture, no dropouts ?
jbeale
Mon Jun 17, 2013 2:08 am
mikerr wrote:HAve you tested that PCB/cable with a longer (10min+) video capture, no dropouts ?
From my experience decoding the RAW camera output, I see that the GPU code includes strong noise reduction. So if the noise pattern from extended cables is single pixel dropouts- even a fairly large number of them- you may never see it in the final output, due to noise reduction algorithms smoothing it out based on neighboring pixels.
rkinch
Mon Jun 17, 2013 4:35 am
jbeale wrote:So if the noise pattern from extended cables is single pixel dropouts- even a fairly large number of them- you may never see it in the final output, due to noise reduction algorithms smoothing it out based on neighboring pixels.
MIPI CSI-2 goes over this cable, correct? Which is serial digital with no error detection or correction? So it is either going to work or not, and any errors in transmission due to cable/connector problems are going to lock things up. Which seems to be just what happens whenever I touch the camera module wrong. It locks up and the software (raspistill, etc) no longer responds, although Linux is still otherwise running fine. I suppose the driver is written primitively as regards errors and doesn't even reset the camera hardware when starting.
towolf
Mon Jun 17, 2013 10:41 am
Yeah that’s mildly annoying. Please put it on the list.
TommyboyNL
Mon Jun 17, 2013 2:23 pm
Good news everyone!
Our missing FPC cables arrived today, and we immediately sent out the first kits!
Woohoo! :D
That is indeed the cable/kit we designed, tested, and are selling right now!
Something like that. When we first got it working, we played with it for about 15 minutes. I just held the camera module in my hand while filming, and we didn't experience any errors.
badgerpi
Mon Jun 17, 2013 2:53 pm
Ordered mine earlier today, and have already got email saying it's been despatched...
Mon Jun 17, 2013 3:17 pm
No, don't think it works like that. There is some error recovery I believe, which I think is done in the HW - there is a HW interface layer between the raw CSI and the GPU drivers. This does all the hard work, so the drivers are written to this interface - means we can make simpler camera drivers, and HW layer also insulates between CSi-2, CCP2 etc.
Don't know why your camera locks when you touch it - I've never had that problem. It may be ESD protection kicking in perhaps? Not sure what the sensor has in that area.
gsh
Mon Jun 17, 2013 3:28 pm
Only issue with the long cable is the EMC noise... The reason the camera connector is so short is because of the EMC... Big cable == more RF noise.
So don't be surprised if you find your WiFi / BT / baby monitor no longer works !
Gordon
Gordon Hollingworth PhD
dan3008
Mon Jun 17, 2013 3:40 pm
Perhaps the addition of some shielding around the cable would help?
dan3008 wrote:Pays your money, takes your choice
jbeale
Mon Jun 17, 2013 6:18 pm
rkinch wrote: Which seems to be just what happens whenever I touch the camera module wrong. It locks up and the software (raspistill, etc) no longer responds, although Linux is still otherwise running fine.
One thing that can cause this is the micro-flex connector "J2" between camera module and camera PCB (visible at upper left in this photo). Several people have reported it being loose, and fixing it by removing and re-installing.
Return to “Camera board”
