I re-seated the connector, but no luck. I have two of the Rev 1.3 cameras and they work perfectly. The two V2.1 cameras do not work.TommyUnger wrote:I hit this issue. The problem for me was the very small wiring on the "P5V04A SUNNY" connector (orange thing on the front of the camera). It was loosened by me. When I pushed it back in, everything was fixed and working again.
Re: Issue with getting camera to work
I experienced the same thing. I realized the problem with mine, was that when I clicked my v2 camera into my Raspberry pi case camera holder slot, that snap was a resistor popping off the 8mp camera board.
If any one is having this issue, there may be a tiny pair of contacts with a letter to mark where something is missing. My v1 camera did not have components so close to that edge.
I understand this thread is pretty old , but i get the same error
I tried
Jun 30 12:15:36 raspberrypi uv4l[1773]: mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
Jun 30 12:15:36 raspberrypi uv4l[1773]: mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
Jun 30 12:15:36 raspberrypi uv4l[1773]: <error> [driver] Failed to create component
Jun 30 12:15:36 raspberrypi uv4l[1773]: <error> [core] open() failed: Out of memory: Operation not permitted error: Operation not permitted
- ofcourse shutdown and reboot
restarting uv4l_raspicam
apt upgrade and update
disabling and enabling camera module
removeing and reattching camera module
Altanai Bisht
tara181989@gmail.com
https://altanaitelecom.wordpress.com/
Book : https://www.https://www.packtpub.com/web-development/webrtc-integrators-guide
same issue here done updagte/upgrade, enabled cam, reseated all 3 connections but still getting error
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
any way to diagnose the issue correctly?
Willie Keeling
I have the same issue. While trying screen mirroring.
Old thread but seems quite some people still facing this issue.
Instead of checking the connector first (which I bet most people got right) remember if you're using raspbian that the camera is deactivated by default and that if you want to activate it you should run `sudo raspi-config` then go to 5. Interfacing options > 1. Camera > Yes > Finalize. This should reset the raspberry and get the camera working most of the time.
I solved the problem. I updated the firmware version.
By :
By :
sudo rpi-update
