JovianPyx
V2 Camera Dead Time Between Timelapse Frames
Thu Jul 16, 2020 2:45 pm
I'm using a V2 camera for night sky work. It is connected to a pi4b 4G RAM with a USB HDD as root filesystem. It is a pi dedicated to the camera.
I am using raspiyuv to capture RGB data with this command:
raspiyuv -n -ss 1000000 -t 40000 -ISO 800 -h 2464 -w 3280 -rgb  -tl 0 -o "image%06d.rgb"
This works, and I get good images (I use imagemagick convert command to convert to displayable format).
Time between frames, however, seems far too long.
First, if I run this with the 'time' command, real is 43.4 seconds when -tl is set to 40000 or 40 seconds.
EDITED: A misread of my screen had the image count at 5. It is 15.
But worse is the fact that during 40 seconds of operation, the camera takes only 15 images. Since the shutter speed is set to 1 second, I expected quite a few more images. in this case, each image is taking about 2.667 seconds to produce.
I've read the documentation about all of the camera software and I am having trouble locating what setting or setting I am using incorrectly or settings I may be missing.
I've read about the fact that some time is needed to transfer the data from the sensor chip over the cable and into RAM, however, I would expect this to be some milliseconds, not 1.667 seconds.
Re: V2 Camera Dead Time Between Timelapse Frames
Thu Jul 16, 2020 3:45 pm
Between each frame it is running the AGC and AWB. If you manually set those you can avoid that.
There's various threads on here about decreasing capture time.
6by9
Thu Jul 16, 2020 5:29 pm
I've covered enough times the mode switching that goes on with the camera stack, so I'm not going to repeat myself again.
Look into -bm (burst mode).
JovianPyx
Thu Jul 16, 2020 6:00 pm
Thank you, the clues were AGC and AWB
Through research here and then a lot of experimentation, I found this to work quite well as a starting point:
raspiyuv -o image%06d.rgb -n -ss 1000000 -t 60000  -h 2464 -w 3280 -rgb -ex off -tl 0 -awb off -bm -md 1 -ag 12.0 -awbg 1.3,1.3
This executes in 61.47 seconds and produces 59 images which is what I expected. Since I have an HQ camera as well, this gives me a leg up on doing the same with it.
For those reading and wondering what all of that does:
-awb off ........... turns off automatic white balance which reduces the time per image, but leaves the images very green.
-awbg 1.3,1.3 .. sets the blue and red gains to 1.3. This was a guess, but it worked well enough. More adjusting for those numbers later.
-ex off ............. exposure mode is off, but can leave the image under exposed.
-ag 12.0 .......... set the sensor's analog gain to 12.0 (the max) to compensate for -ex off
-md 1 .............. There's several modes which are fast, 1 is one of them, image quality seems unaffected by changing it, but brightness can be low
EDIT ADD:
I used
raspistill -t0
to cause the camera to use it's default automatic controls including AWB. I then ran
raspistill --settings
which has information about the red and blue gain settings. These are shown as fractions of integers over integers which I converted to floating point with a calculator. I then used those red and blue values in -awbg and I get satisfactory white balance. So I just used the camera to generate the values once, then turn off AWB and apply them all the time. Tweaking may be necessary, but it looks very good to me.
Here is a bash shell script I wrote to compute the floating point values from the integer fractions and display them. You can easily see the conditions under which white balance was computed.
echo "starting camera in automatic mode"
raspistill -t 5000
echo "reading settings"
raspistill --settings 2> /tmp/settings
cat /tmp/settings | while read L1
  do
  read L2
  AG=$(echo "$L1" | cut -d',' -f2)
  AG=$(echo "$AG" | cut -d' ' -f4)
  AG=$(echo "scale=2; $AG" | bc -q)
  DG=$(echo "$L1" | cut -d',' -f3)
  DG=$(echo "$DG" | cut -d' ' -f4)
  DG=$(echo "scale=2; $DG" | bc -q)
  RED=$(echo "$L2" | tr '=,' '  ' | cut -d' ' -f4)
  RED=$(echo "scale=2; $RED" | bc -q)
  BLU=$(echo "$L2" | tr '=,' '  ' | cut -d' ' -f7)
  BLU=$(echo "scale=2; $BLU" | bc -q)
  echo -e "analog gain: $AG | digital gain: $DG \t| RED,BLUE: $RED,$BLU"
  done
rm /tmp/settings
Return to “Camera board”
