half-transparent overlay for stop motion?
Posted: Wed May 20, 2020 3:49 am
by jbeale
One of the RPi project pages shows a simple stop-motion project using the Pi camera:
https://projects.raspberrypi.org/en/pro ... top-motion
The new High Quality pi camera is more interesting to me for this use than the previous pi cams, because of the variety of available C/CS lenses with manual adjustments for focus, aperture etc. The one thing I haven't seen is a program that provides the "onion skin" function that most smartphone stop-motion apps have, where the previous captured frame is overlaid with (for example) 50% transparency on the live view. Is this something anyone has tried before, if it is possible?
Thinking about it, in this case you don't necessarily need a high framerate, or max resolution on the live view. So I guess you could just take a series of stills MJPEG style, and combine the images on the CPU without needing real alpha-compositing on live video preview from the GPU side.
Re: half-transparent overlay for stop motion?
Posted: Wed May 20, 2020 6:54 am
by ethanol100
I think this could be done with picamera. You could modify overlaying images on the preview to use the last captured file?
Posted: Wed May 20, 2020 6:59 am
by HermannSW
Things like that can be done with dispmanx API. Near zero documentation. But AndrewFromMelbourne created a nice repo with many samples:
https://github.com/AndrewFromMelbourne/raspidmx
I forked it in order to create a i420 live video viewer that would allow to view live raspividyuv stream of frames. I based it on rgb_triangle demo.
For your application alpha blending is available in dispmanx as well. I have not tried, but radar_sweep_alpha demo seems to demonstrate what you want.
P.S:
His raspi2png takes screenshot inclusive overlays, regardless whether in console or X11 mode, and uses dispmanx API as well:
https://github.com/AndrewFromMelbourne/raspi2png
