Farfar
What camera for 20x20 cm @ 15cm?
Mon May 18, 2020 11:15 am
Hello.
We are making a sort-photo-booth.. its a "Tile-O-matic" and we need to take a picture of a cement tile from 15cm above the tile, and then multiply this 4 times (or more) to see the pattern. Any suggestions on which camera we should use?
The camera has to sit 15 cm above the tile and need to cover min 20x20cm (Square). Output will be to a regular monitor 90 degrees turned
see photo.
The "machine"
Open drawer
Lid for placement of camera
gordon77
Re: What camera for 20x20 cm @ 15cm?
Wed May 20, 2020 2:21 pm
go here https://www.scantips.com/lights/fieldofview.html#top and enter the details for the pi cameras, 2 examples below
the v2 camera would need a 2mm lens, the new hq camera a 3.5mm lens to cover 20cm at 15cm
gordon77
ethanol100
Wed May 20, 2020 3:55 pm
Do the 15cm include the camera and lens, too? Then you will be even closer and need a smaller focal length..
You could try to buy the official v2 camera and replace the camera module with something like this (The focal length they mention is not correct, it is more like I would roughly estimate around 1.85mm).
You will still need some image processing to rectify the fish-eye like view, and for tiling, you will need some processing, to cut/rotate the tile.
Overall a nice little project, I like the idea.
HermannSW
Wed May 20, 2020 4:38 pm
E.g. OpenCV Camera calibration with samples/python/calibrate.py demo (HQ camera photo below):
viewtopic.php?f=43&t=272658&p=1663011#p1662752
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/github_repo_i420toh264
ethanol100
Wed May 20, 2020 4:58 pm
With the lens mentioned in my previous post, you would get an image like this(I had to use a tripod, which blocks part of the view, camera only badly alligned...):
The sensor was about 15cm away from the surface, maybe a bit less. I have drawn the 20x20cm square.
You could try to find a lens with a bit higher focal length, but this is one possibility which is directly available. You can use the image processing HermannSW suggested.
Farfar
Fri May 22, 2020 8:54 am
Fantastic. Thank you so much guys.
Factoring in the height of the lens as i see it from your test @ethanol100 is not needed i think. it looks like we have a lot of real-estate around to spare.
We could if needed, embed the camera into the lid, to compensate for the lens. But again, it looks like we have plenty of FOV. Great test, if you ever pop-by Oslo, come by and claim your prize. ;) (There wasn't a prize in the beginning of this thread, but there is now)
Regarding rotation, this will only apply to some of the tiles. Some dont mind being rotated, others should not be rotated.
Should we solve this with a "rotate option" on a button, (we are not planning on using a touch screen). We will be using an old
Samsung 24" 1920x1200 (S24E650XW)
Some patterns is fine in 4x4, others need 6x6, but i guess we could just fill the screen.
Or is there a wow-zee-pattern recognition algorithm out there that "understands" how it should be.
Enclosed is some photos of the different tile-setup for rotation, does not mind rotation and can´t be rotated.
This need rotation and add..
This one does not mind being rotated
Can´t rotate
Return to “Camera board”
