ethanol100
Exif lens related tags for HQ Camera
Sat May 09, 2020 4:13 pm
What is the recommend way to set lens parameters for raspistill?
Currently, the jpeg encoder adds a focal length of 3.0 mm and an aperture of 2 as a default parameter.
HermannSW
Re: Exif lens related tags for HQ Camera
Sat May 09, 2020 4:17 pm
From other thread showing what ethanol100 stated:
https://stamm-wilbrandt.de/github_repo_i420toh264
Sat May 09, 2020 7:33 pm
Hmm, I seem to remember putting in code to allow you to set your own exif tags, but whether you can change the focal length tag I don't remember. Something like:
raspistill --exif FocalLength=10
I'll take a closer look on Monday if that doesn't work. It was a long time ago!
ethanol100
Sat May 09, 2020 8:07 pm
Yes, I had tried the add exif command, but this did not seem to work for with setting FocalLength.
It would be nice if you could have a look next week, but it is not urgent.
We can use for example
to manually change the exif data of an image after capture.
gordon77
Sat May 09, 2020 8:41 pm
Raspicam documentation appears to show
--exif --EXIF.FocalLengthIn35mmFilm
but l've never tried it.
Sun May 10, 2020 9:46 am
Ah, maybe it should be
--exif EXIF.FocalLength=<blah>
6by9
Sun May 10, 2020 2:17 pm
It's the weekend so I'm not looking up source code.
I'm cheating and looking at the strings in the firmware
pi@raspberrypi:/boot $ strings start_x.elf | grep EXIF
EXIF.Flash
EXIF.Fnumber
EXIF.MakerNote
EXIF.FocalLength
EXIF.ExposureTime
EXIF.MeteringMode
EXIF.ExposureMode
EXIF.WhiteBalance
EXIF.ExposureIndex
EXIF.ApertureValue
EXIF.BrightnessValue
EXIF.ISOSpeedRatings
EXIF.ExposureProgram
EXIF.MaxApertureValue
EXIF.DateTimeOriginal
EXIF.ShutterSpeedValue
EXIF.DateTimeDigitized
EXIF.
EXIF.
EXIF.
EXIF.#TagsPresent
pi@raspberrypi:/boot $ strings start_x.elf | grep IFD
IFD0.Model
IFD0.DateTime
IFD0.
IFD1.
IFD0.
IFD1.
IFD0.
IFD1.
IFD0.#TagsPresent
IFD1.#TagsPresent
So "EXIF.FocalLength=" would appear to be the winner.
ethanol100
Sun May 10, 2020 5:03 pm
Still it does not seem to work. I used
raspistill -o test.jpg --exif EXIF.FocalLength=50
If I look at exiftool -v3 test.jpg I get:
  ExifToolVersion = 11.16
  Directory = .
  FileSize = 2464394
  FileModifyDate = 1589129453
  FileAccessDate = 1589129452
  FileInodeChangeDate = 1589129453
  FilePermissions = 33188
  FileType = JPEG
  FileTypeExtension = JPG
  MIMEType = image/jpeg
JPEG APP1 (25624 bytes):
    0006: 45 78 69 66 00 00 4d 4d 00 2a 00 00 00 08 00 0a [Exif..MM.*......]
    0016: 01 00 00 04 00 00 00 01 00 00 0f d8 01 01 00 04 [................]
    0026: 00 00 00 01 00 00 0b e0 01 0f 00 02 00 00 00 0c [................]
    0036: 00 00 00 86 01 10 00 02 00 00 00 09 00 00 00 92 [................]
    0046: 01 1a 00 05 00 00 00 01 00 00 00 9c 01 1b 00 05 [................]
    0056: 00 00 00 01 00 00 00 a4 01 28 00 03 00 00 00 01 [.........(......]
    0066: 00 02 00 00 01 32 00 02 00 00 00 14 00 00 00 ac [.....2..........]
    [snip 25512 bytes]
  ExifByteOrder = MM
  + [IFD0 directory with 10 entries]
  | 0)  ImageWidth = 4056
  |     - Tag 0x0100 (4 bytes, int32u[1]):
  |         001e: 00 00 0f d8                                     [....]
  | 1)  ImageHeight = 3040
  |     - Tag 0x0101 (4 bytes, int32u[1]):
  |         002a: 00 00 0b e0                                     [....]
  | 2)  Make = RaspberryPi
  |     - Tag 0x010f (12 bytes, string[12]):
  |         0092: 52 61 73 70 62 65 72 72 79 50 69 00             [RaspberryPi.]
  | 3)  Model = RP_testc
  |     - Tag 0x0110 (9 bytes, string[9]):
  |         009e: 52 50 5f 74 65 73 74 63 00                      [RP_testc.]
  | 4)  XResolution = 72 (72/1)
  |     - Tag 0x011a (8 bytes, rational64u[1]):
  |         00a8: 00 00 00 48 00 00 00 01                         [...H....]
  | 5)  YResolution = 72 (72/1)
  |     - Tag 0x011b (8 bytes, rational64u[1]):
  |         00b0: 00 00 00 48 00 00 00 01                         [...H....]
  | 6)  ResolutionUnit = 2
  |     - Tag 0x0128 (2 bytes, int16u[1]):
  |         0066: 00 02                                           [..]
  | 7)  ModifyDate = 2020:05:10 18:50:52
  |     - Tag 0x0132 (20 bytes, string[20]):
  |         00b8: 32 30 32 30 3a 30 35 3a 31 30 20 31 38 3a 35 30 [2020:05:10 18:50]
  |         00c8: 3a 35 32 00                                     [:52.]
  | 8)  YCbCrPositioning = 1
  |     - Tag 0x0213 (2 bytes, int16u[1]):
  |         007e: 00 01                                           [..]
  | 9)  ExifOffset (SubDirectory) -->
  |     - Tag 0x8769 (4 bytes, int32u[1]):
  |         008a: 00 00 00 c0                                     [....]
  | + [ExifIFD directory with 22 entries]
  | | 0)  ExposureTime = 0.124984 (124984/1000000)
  | |     - Tag 0x829a (8 bytes, rational64u[1]):
  | |         01da: 00 01 e8 38 00 0f 42 40                         [...8..B@]
  | | 1)  ExposureProgram = 3
  | |     - Tag 0x8822 (2 bytes, int16u[1]):
  | |         00e2: 00 03                                           [..]
  | | 2)  ISO = 250
  | |     - Tag 0x8827 (2 bytes, int16u[1]):
  | |         00ee: 00 fa                                           [..]
  | | 3)  ExifVersion = 0220
  | |     - Tag 0x9000 (4 bytes, undef[4]):
  | |         00fa: 30 32 32 30                                     [0220]
  | | 4)  DateTimeOriginal = 2020:05:10 18:50:52
  | |     - Tag 0x9003 (20 bytes, string[20]):
  | |         01e2: 32 30 32 30 3a 30 35 3a 31 30 20 31 38 3a 35 30 [2020:05:10 18:50]
  | |         01f2: 3a 35 32 00                                     [:52.]
  | | 5)  CreateDate = 2020:05:10 18:50:52
  | |     - Tag 0x9004 (20 bytes, string[20]):
  | |         01f6: 32 30 32 30 3a 30 35 3a 31 30 20 31 38 3a 35 30 [2020:05:10 18:50]
  | |         0206: 3a 35 32 00                                     [:52.]
  | | 6)  ComponentsConfiguration = 1 2 3 0
  | |     - Tag 0x9101 (4 bytes, undef[4] read as int8u[4]):
  | |         011e: 01 02 03 00                                     [....]
  | | 7)  ShutterSpeedValue = 3.000184 (3000184/1000000)
  | |     - Tag 0x9201 (8 bytes, rational64s[1]):
  | |         020a: 00 2d c7 78 00 0f 42 40                         [.-.x..B@]
  | | 8)  ApertureValue = 2 (20000/10000)
  | |     - Tag 0x9202 (8 bytes, rational64u[1]):
  | |         0212: 00 00 4e 20 00 00 27 10                         [..N ..'.]
  | | 9)  BrightnessValue = 0.01 (1/100)
  | |     - Tag 0x9203 (8 bytes, rational64s[1]):
  | |         021a: 00 00 00 01 00 00 00 64                         [.......d]
  | | 10) MaxApertureValue = 2 (20000/10000)
  | |     - Tag 0x9205 (8 bytes, rational64u[1]):
  | |         0222: 00 00 4e 20 00 00 27 10                         [..N ..'.]
  | | 11) MeteringMode = 2
  | |     - Tag 0x9207 (2 bytes, int16u[1]):
  | |         015a: 00 02                                           [..]
  | | 12) Flash = 0
  | |     - Tag 0x9209 (2 bytes, int16u[1]):
  | |         0166: 00 00                                           [..]
  | | 13) FocalLength = 3.039 (30390/10000)
  | |     - Tag 0x920a (8 bytes, rational64u[1]):
  | |         022a: 00 00 76 b6 00 00 27 10                         [..v...'.]
  | | 14) MakerNoteUnknownText = ev=-1 mlux=-1 exp=124984 ag=1507 focus=255 gain_r=2.90[snip]
  | |     - Tag 0x927c (356 bytes, undef[356]):
  | |         0232: 65 76 3d 2d 31 20 6d 6c 75 78 3d 2d 31 20 65 78 [ev=-1 mlux=-1 ex]
  | |         0242: 70 3d 31 32 34 39 38 34 20 61 67 3d 31 35 30 37 [p=124984 ag=1507]
  | |         0252: 20 66 6f 63 75 73 3d 32 35 35 20 67 61 69 6e 5f [ focus=255 gain_]
  | |         0262: 72 3d 32 2e 39 30 36 20 67 61 69 6e 5f 62 3d 31 [r=2.906 gain_b=1]
  | |         0272: 2e 39 31 30 20 67 72 65 65 6e 6e 65 73 73 3d 30 [.910 greenness=0]
  | |         [snip 276 bytes]
  | | 15) FlashpixVersion = 0100
  | |     - Tag 0xa000 (4 bytes, undef[4]):
  | |         018a: 30 31 30 30                                     [0100]
  | | 16) ColorSpace = 1
  | |     - Tag 0xa001 (2 bytes, int16u[1]):
  | |         0196: 00 01                                           [..]
  | | 17) ExifImageWidth = 4056
  | |     - Tag 0xa002 (4 bytes, int32u[1]):
  | |         01a2: 00 00 0f d8                                     [....]
  | | 18) ExifImageHeight = 3040
  | |     - Tag 0xa003 (4 bytes, int32u[1]):
  | |         01ae: 00 00 0b e0                                     [....]
  | | 19) InteropOffset (SubDirectory) -->
  | |     - Tag 0xa005 (4 bytes, int32u[1]):
  | |         01ba: 00 00 03 8a                                     [....]
  | | + [InteropIFD directory with 1 entries]
  | | | 0)  InteropIndex = R98
  | | |     - Tag 0x0001 (4 bytes, string[4]):
  | | |         03a0: 52 39 38 00                                     [R98.]
  | | 20) ExposureMode = 0
  | |     - Tag 0xa402 (2 bytes, int16u[1]):
  | |         01c6: 00 00                                           [..]
  | | 21) WhiteBalance = 0
  | |     - Tag 0xa403 (2 bytes, int16u[1]):
  | |         01d2: 00 00                                           [..]
  + [IFD1 directory with 8 entries]
  | 0)  ImageWidth = 64
  |         03b2: 00 00 00 40                                     [...@]
  | 1)  ImageHeight = 48
  |         03be: 00 00 00 30                                     [...0]
  | 2)  Compression = 6
  |     - Tag 0x0103 (2 bytes, int16u[1]):
  |         03ca: 00 06                                           [..]
  | 3)  XResolution = 72 (72/1)
  |         040e: 00 00 00 48 00 00 00 01                         [...H....]
  | 4)  YResolution = 72 (72/1)
  |         0416: 00 00 00 48 00 00 00 01                         [...H....]
  | 5)  ResolutionUnit = 2
  |         03ee: 00 02                                           [..]
  | 6)  ThumbnailOffset = 1042
  |     - Tag 0x0201 (4 bytes, int32u[1]):
  |         03fa: 00 00 04 12                                     [....]
  | 7)  ThumbnailLength = 24576
  |     - Tag 0x0202 (4 bytes, int32u[1]):
  |         0406: 00 00 60 00                                     [..`.]
JPEG DQT (130 bytes):
    6422: 00 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 [................]
    6432: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 [................]
    6442: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 [................]
    6452: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 [................]
    6462: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 [................]
    6472: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 [................]
    6482: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 [................]
    [snip 18 bytes]
JPEG SOF0 (15 bytes):
    64a8: 08 0b e0 0f d8 03 01 22 00 02 11 01 03 11 01    [.......".......]
  ImageWidth = 4056
  ImageHeight = 3040
  EncodingProcess = 0
  BitsPerSample = 8
  ColorComponents = 3
JPEG DHT (416 bytes):
    64bb: 00 00 01 05 01 01 01 01 01 01 00 00 00 00 00 00 [................]
    64cb: 00 00 01 02 03 04 05 06 07 08 09 0a 0b 10 00 02 [................]
    64db: 01 03 03 02 04 03 05 05 04 04 00 00 01 7d 01 02 [.............}..]
    64eb: 03 00 04 11 05 12 21 31 41 06 13 51 61 07 22 71 [......!1A..Qa."q]
    64fb: 14 32 81 91 a1 08 23 42 b1 c1 15 52 d1 f0 24 33 [.2....#B...R..$3]
    650b: 62 72 82 09 0a 16 17 18 19 1a 25 26 27 28 29 2a [br........%&'()*]
    651b: 34 35 36 37 38 39 3a 43 44 45 46 47 48 49 4a 53 [456789:CDEFGHIJS]
    [snip 304 bytes]
JPEG SOS
JPEG EOI
So, yes, FocalLength is tag 0x920a in subdirectory ExifIFD. I also tried EXIF.FocalLength=50/1, and all possible combinations for lower/upper case, but the value keeps to be (30390/10000).
By the way, thanks for answering questions on the weekend!
Sun May 10, 2020 7:22 pm
  Directory = .
  FileSize = 2464394
  FileType = JPEG
    [snip 25512 bytes]
  ExifByteOrder = MM
  | 3)  Model = RP_testc
  |         0066: 00 02                                           [..]
  |         007e: 00 01                                           [..]
  | |         00e2: 00 03                                           [..]
  | | 2)  ISO = 250
  | |         00ee: 00 fa                                           [..]
  | |         015a: 00 02                                           [..]
  | | 12) Flash = 0
  | |         0166: 00 00                                           [..]
  | |         [snip 276 bytes]
  | | 16) ColorSpace = 1
  | |         0196: 00 01                                           [..]
  | |         01c6: 00 00                                           [..]
  | |         01d2: 00 00                                           [..]
  | 0)  ImageWidth = 64
  | 1)  ImageHeight = 48
  | 2)  Compression = 6
  |         03ca: 00 06                                           [..]
  |         03ee: 00 02                                           [..]
    [snip 18 bytes]
  ImageWidth = 4056
  ImageHeight = 3040
  EncodingProcess = 0
  BitsPerSample = 8
  ColorComponents = 3
    [snip 304 bytes]
JPEG SOS
JPEG EOI
It's the weekend?
Mon May 11, 2020 11:39 am
OK, think there is a minor bug in the firmware which means the camera is reporting it has a focal length of 3.04 (hangover from the driver it was based off) which I suspect is overwriting the incoming data from raspistill. I've got an internal fix in progress.
ethanol100
Mon May 11, 2020 12:22 pm
Great, thank you for looking into this.
Could you also check if the same applies for the EXIF.ApertureValue?
Mon May 11, 2020 1:16 pm
It probably does, just checking.
ethanol100
Thu May 21, 2020 6:47 am
Thank you, setting focal length and F-number now works with last rpi-update!
raspistill -o test.jpg --exif EXIF.FocalLength=50/1 --exif EXIF.FNumber=8/3
Just as a side note: These values need to be given as fractions, else the FocalLength shows as 0.00mm (it writes for example [50/0] into the exif tag).
Return to “Camera board”
