Vijayashri
controlling the duration of white led connected to GPIO in Rpi 4
Mon Apr 27, 2020 6:38 am
I am using Rpi 4 with camera. I have connected a white led to a GPIO pin and activating the pin using .dts file. by running the code the led flashes twice which is standard (as read from the Rpi documentation) the two flashes takes around 2 seconds. I am unable to control the duration and is there a way to make only one flash with led? any info about this will be very helpful
Return to “Camera board”
