lagurus
raspistill on RPI4 - failed to add service
Thu Apr 16, 2020 9:19 am
Hi all,
when is started following:
raspistill --gl --glscene sobel
it return only
* failed to add service - already in use?
Configuration: RPI 4 4GB running Raspbian Buster.
For older model (PI,PI2B,PI3B) it works.
Any chance to get it work again?
Thanks.
6by9
Re: raspistill on RPI4 - failed to add service
Thu Apr 16, 2020 2:56 pm
Not without significant reworking.
The Pi4 has the next generation of the 3D core, and the firmware doesn't know how to drive it. You need to use the desktop Mesa GL stack instead of the firmware GLES driver.
lagurus
Fri Apr 17, 2020 4:47 pm
Any chance to make it oneself?
Is enough to modify raspicam tree - e.g. files like RapiTex.c and RaspiTexUtil.h?
Or is needed to change also something deeper - e.g. in firmware?
Fri Apr 17, 2020 4:52 pm
You would need to rework the raspicam code to use the Mesa GL stack instead of the current mechanism which uses the firmware 3D. I am no expert on this, I suspect it's feasible, but I have no idea how to do it. Probably not a huge amount of work for someone who is familiar with the Mesa, but not trivial.
lagurus
Fri Jul 17, 2020 10:03 am
Resurrecting old post.
Finally I had time and tried to modify my code.
It seems that error message:
is gone.
I am using Mesa GL. For creation is used DRM/GBM stuff (beacuse I am headless).
Also was needed to link program with GLESv2,EGL instead of brcmGLESv2,brcmEGL
Some functions are not defined in MESA EGL and need to be added dynamically using eglGetProcAddress e.g.:
eglCreateImageKHR
eglDestroyImageKHR
glEGLImageTargetTexture2DOES
But now receive EGL error 0x300c in function raspitexutil_do_update_texture during calling of
eglCreateImageKHR
. Error 0x300c = EGL_BAD_PARAMETER.
I have noticed that function eglCreateImageKHR was originally defined in egl_khr_image_client.c which I think is used when
is program linked against brcmEGL. But MESA EGL hasn't it defined it in such way and don't know anything about:
EGL_IMAGE_BRCM_MULTIMEDIA,EGL_IMAGE_BRCM_MULTIMEDIA_Y,EGL_IMAGE_BRCM_MULTIMEDIA_U,EGL_IMAGE_BRCM_MULTIMEDIA_V
Some tips how to solve this issue?
How to add support to PI4? I have used it on PI1/2/3 for fast image processing using shaders.
Thank you.
Return to “Camera board”
