raspberry_user
Does the length of the cable to connect the Pi Camera V2 to the Pi matters?
Fri Mar 20, 2020 2:48 pm
Hi, I am considering to buy the official Camera Module V2. I know that it comes with a cable to connect to the Pi but it is too short. For my project, I need at least 300 mm. If I go for a longer 400mm or even 500mm cable, will there be any cons on that? Will the extra length affects the quality of the input images or transfer speed?
topguy
Re: Does the length of the cable to connect the Pi Camera V2 to the Pi matters?
Fri Mar 20, 2020 3:17 pm
Adafruit has been selling cables at least 24" ( 610mm ) https://www.adafruit.com/product/1731 so its possible to use the camera with those kind of lengths.
Will it work for all cameras models, resolutions and environments ? maybe.. longer cables means it picks up more noise so your exact results might vary from others.
Fri Mar 20, 2020 3:44 pm
Just a noisier image, until it stops working altogether. Also depends on the environment.
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
raspberry_user
Fri Mar 20, 2020 5:23 pm
Thanks. So, rather than future proofing, get a cable of length just long enough to get the current job done?
HermannSW
Fri Mar 20, 2020 11:39 pm
I use 1m and 2m cables routinely without problems -- officially supported cable max length is 15cm.
Here you can see 1m cable of my WoodenBoardPi:
viewtopic.php?f=45&t=254059&p=1623477#p1550239
https://stamm-wilbrandt.de/github_repo_i420toh264
PhatFil
Sat Mar 21, 2020 12:57 am
Folding aluminium foil around the ribbon cable could provide shielding if you encounter issues due to environmental noise.
Return to “Camera board”
