rbn
Broken connector clamp on Camera Board
Wed Jan 15, 2020 7:00 pm
The black retaining clip for the ribbon cable connector on my raspberry pi camera board is broken and has disappeared. Any suggestions on acquiring a replacement clip to clamp the cable into the connector? Or suggestions for another solution (not gluing the cable).
pcmanbob
Re: Broken connector clamp on Camera Board
Wed Jan 15, 2020 9:17 pm
The only way to get another clip is to buy a replacement socket of the same type and transfer the clip but you will probably break it anyway as they are not designed to be removed once fitted.
It may even be the socket that was damaged that allowed the clip to drop off.
You could try using some plastic to jam the cable in much like the clip does.
Imperf3kt
Wed Jan 15, 2020 10:37 pm
Cardboard from a cereal pack or plastic from a milk container, both of these are about the right thickness to friction hold the cable like the original plastic clamp does.
55:55:44:44:4C
52:4C:52:42:41
HermannSW
Wed Jan 15, 2020 11:48 pm
Another option is sharing clamp among PIs.
I have several Pi Zeros and don't use them all together at once.
I lost two clamps, but was able to move clamps to the Zeros used.
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
rbn
Fri Jan 17, 2020 12:39 pm
Thanks to all. I eventually manged it with a piece of card. Not as secure as the original but seems to do OK.
Return to “Camera board”
