HermannSW
Raspberry v2 camera [email protected]
Wed Jan 15, 2020 1:36 pm
Raspberry v2 camera allows for framerate up to 200fps with raspivid mode 7.
Documentation has comment on what to do when using >120fps:
https://www.raspberrypi.org/documentati ... /camera.md
I never used "-ex off" and got [email protected] without frameskips often in different scenarios, until yesterday.
I did want to record the drops of medicine falling onto a spoon.
Before doing so, I did this command for adjusting camera to scene:
raspivid -md 7 -w 640 -h 480 -p 22,50,640,480 -fps 150 -pts tst.pts -o tst.h264 -t 0
I have done that so often before, but was not able to get away without frameskips while recording this constant scene:
I don't get what is so complex in that (constant) scene.
I even replaced locations to to ramdisk ("/dev/shm/tst.pts" and "/dev/shm/tst.h264"), no change.
I went down to 120fps and still frameskips.
Finally I ended up with 101fps (not 100fps because "./ptsanalyze tst.pts 0" does not like it) with no frameskips:
https://github.com/Hermann-SW/userland/ ... ptsanalyze
I did "ffmepg -i tst.h264 frame.%04d.pnm", selected interesting range for frames, did pnmrotate all frames by -90°, copied frames in reverse order after end of sequence for back-and-forth, and used gifenc.sh to create a 25fps animated gif, playing 4 times slower than real. Looks nice:
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
Return to “Camera board”
