bostonmacosx
Help with multi camera setup . 4 individual Pi0 with pi4 Hub...
Wed Jan 08, 2020 11:10 pm
i'm setting up a rig to monitor an athletic event....ala watch the athlete.
I'm hoping to achieve the following.
4 Pi cameras or other....
720p 60fps-90fps
wired ethernet to a switch that has a Rpi4 as the hub of activity.....controlling some servo motors etc etc.
Closed network where the Pi4 acts as a hub so a tablet can connect and view the video.
i'm not even sure if this is possible.
Can I do 90fps on a Pi0? amongst other question.
HermannSW
Re: Help with multi camera setup . 4 individual Pi0 with pi4 Hub...
Thu Jan 09, 2020 1:19 am
720p 60fps-90fps
With a (current) Raspberry v2 camera, yes (40-90fps for mode 6):
https://www.raspberrypi.org/documentati ... /camera.md
I would have said yes, did connect v2 camera to Pi Zero and tried.
With "-fps 90" there are 10% frameskips, so I would go with 80fps on Pi Zero without frameskips:
https://github.com/Hermann-SW/userland/ ... ptsanalyze
[email protected]:~ $ raspivid -md 6 -w 1280 -h 720 -pts tst.pts -o tst.h264 -awb greyworld -fps 80
Too many macroblocks/s: Increasing H264 Level to 4.2
[email protected]:~ $ ./ptsanalyze tst.pts 0
creating tstamps.csv
391 frames were captured at 80fps
frame delta time[us] distribution
1 12453
1 12455
1 12459
15 12460
23 12461
56 12462
119 12463
99 12464
41 12465
23 12466
7 12467
1 12471
1 12473
after skip frame indices (middle column)
0 frame skips (0%)
Interestingly you can do [email protected] without frameskips on Pi Zero as well:
[email protected]:~ $ raspivid -md 7 -w 640 -h 480 -pts tst.pts -o tst.h264 -awb greyworld -fps 150
750 frames were captured at 150fps
1 6606
1 6608
1 6615
1 6617
1 6623
1 6625
1 6626
1 6631
1 6632
1 6633
3 6634
2 6635
5 6636
18 6637
31 6638
108 6639
181 6640
165 6641
125 6642
64 6643
12 6644
8 6645
2 6646
3 6648
3 6650
1 6654
1 6655
1 6656
1 6662
1 6665
1 6673
1 6674
0 frame skips (0%)
https://www.raspberrypi.org/forums/view ... 3&t=252176
I used a PT servo camera system:
But lately I prefer self-built ("4 drops of superglue") PT stepper camera system
(more fine grain moves, 11.3hsteps/1° instead of 1step/1°):
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
bostonmacosx
Thu Jan 09, 2020 1:43 am
Thanks so much for the info. Totally what I'm looking for before buying equipment.
Does the ethernet to the hub and then a Pi4 to record the streams and act as the NVR seem reasonable.....WiFi on the Pi4 would aalso act as an entry point for the tablet to view the streams.....
Return to “Camera board”
