HermannSW
Why is post raw "yuv to .h264" compression 1/3rd size of .h264?
Tue Jan 07, 2020 11:29 am
I recently realized that you can use raspivid to generate raw output (yuv and rgb) concurrently with h264 output.
So I used this command to create tst.h264 and /dev/shm/tst.i420 in parallel from same recording:
$ raspivid -md 7 -w 640 -h 480 -rf yuv -r /dev/shm/tst.i420 -o tst.h264
GraphvizFiddle share link
I used i420toh264 tool, that is based on "/opt/vc/src/hello_pi/hello_encode/"
https://github.com/Hermann-SW2/userland ... i420toh264
to create .h264 file from /dev/shm/tst.i420 as well:
$ userland/host_applications/linux/apps/hello_pi/i420toh264/i420toh264 tst.h264b 640 480 < /dev/shm/tst.i420
I cannot see differences in the generated .h264 videos.
Why is the file GPU compressed to .h264 in postprocessing only 1/3rd of size of tst.h264?
[email protected]:~ $ ls -l tst.h264*
-rw-r--r-- 1 pi pi 2688539 Jan  7 12:11 tst.h264
-rw-r--r-- 1 pi pi  827084 Jan  7 12:13 tst.h264b
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
Re: Why is post raw "yuv to .h264" compression 1/3rd size of .h264?
Tue Jan 07, 2020 11:44 am
Are you using the same bit rate in both encodes?
6by9
Tue Jan 07, 2020 11:55 am
I suspect you've messed up the timestamp and framerate information, so bitrate control will be doing very different things.
I'm assuming OV5647, so mode 7 is a minimum of 60fps. The video_encode component in raspivid will therefore be seeing timestamps for frames at 16ms intervals. It's also defaulted to a bitrate of 17Mbit/s.
Your app is telling video_encode that it is a 30fps stream, not providing any timestamps (nTimeStamp field in OMX_BUFFERHEADERTYPE), and requesting a bitrate of 1Mbit/s.
Ask for different encoding parameters and you'll get very different files.
HermannSW
Tue Jan 07, 2020 6:08 pm
Thanks for the responses.
I did use a v2 camera.
And the analysis wrt framerate and bitrate was correct.
I did change i420toh264 framerate to 60 and and bitrate to 17,000,000 and recompiled.
Since the Pi was rebooted /dev/shm/tst.i420 from noon was gone.
So I repeated the experiment, and this time the generated .h264 files are roughly the same size.
Finally I kept bitrate and changed framerate back to 30, and got same .h264 size as well:
-rw-r--r-- 1 pi pi 3529520 Jan  7 18:57 tst.h264
-rw-r--r-- 1 pi pi 3539499 Jan  7 19:00 tst.h264c
-rw-r--r-- 1 pi pi 3555870 Jan  7 19:05 tst.h264d
So it seems that bitrate alone is the factor for .h264 size when converting from .i420 to .h264.
Interesting that both noon videos looked "the same" to me despite the big differences in bitrate and .h264 size.
6by9
Tue Jan 07, 2020 6:35 pm
1Mbit/s should be sufficient for VGA, probably even 512kbit/s.
17Mbit/s is the default as the default resolution is 1080p30.
Somewhere around 8Mbit/s would be recommended for 720p30.
Scale down accordingly.
HermannSW
Tue Jan 07, 2020 8:41 pm
Thank you again
I just recorded a 640x480 v2 camera video with default 5s length and used "ffmpeg -i tst.h264 frame.%04.pnm" to get the frames, and I got 196 frames. According to doc camera.md minimum/default for imx219 v2 camera mode 7 is 40fps, max without limitations is 120fps. I typically get 150fps without frameskips and absolute max is 200fps with limitations.
Return to “Camera board”
