Benjamin1818
Will this camera live streaming to web page code always be running even when a client is not watching?
Fri Jan 03, 2020 6:04 am
I am going to be live streaming a raspberry pi camera as a security camera on a web page. ( Code below) How much data will it use? Also, will the live stream only be running when someone is watching? Thank you!
Code:
import io
import picamera
import logging
import socketserver
from threading import Condition
from http import server
PAGE=
<html>
<head>
<title>The PlantCam</title>
</head>
<body>
<center><h1>The PlantCam</h1></center>
<center><img src="stream.mjpg" width="640" height="480"></center>
<script type="text/javascript">
var idleTime = 0;
$(document).ready(function () {
    //Increment the idle time counter every minute.
    var idleInterval = setInterval(timerIncrement, 60000); // 1 minute
    //Zero the idle timer on mouse movement.
    $(this).mousemove(function (e) {
        idleTime = 0;
    $(this).keypress(function (e) {
        idleTime = 0;
function timerIncrement() {
    idleTime = idleTime + 1;
    if (idleTime > 2) { // 3 minutes
        window.location.reload();
</script>
</body>
</html>
class StreamingOutput(object):
    def __init__(self):
        self.frame = None
        self.buffer = io.BytesIO()
        self.condition = Condition()
    def write(self, buf):
        if buf.startswith(b'\xff\xd8'):
            # New frame, copy the existing buffer's content and notify all
            # clients it's available
            self.buffer.truncate()
            with self.condition:
                self.frame = self.buffer.getvalue()
                self.condition.notify_all()
            self.buffer.seek(0)
        return self.buffer.write(buf)
class StreamingHandler(server.BaseHTTPRequestHandler):
    def do_GET(self):
        if self.path == '/':
            self.send_response(301)
            self.send_header('Location', '/index.html')
            self.end_headers()
        elif self.path == '/index.html':
            content = PAGE.encode('utf-8')
            self.send_response(200)
            self.send_header('Content-Type', 'text/html')
            self.send_header('Content-Length', len(content))
            self.end_headers()
            self.wfile.write(content)
        elif self.path == '/stream.mjpg':
            self.send_header('Age', 0)
            self.send_header('Cache-Control', 'no-cache, private')
            self.send_header('Pragma', 'no-cache')
            self.send_header('Content-Type', 'multipart/x-mixed-replace; boundary=FRAME')
            self.end_headers()
            try:
                while True:
                    with output.condition:
                        output.condition.wait()
                        frame = output.frame
                    self.wfile.write(b'--FRAME\r\n')
                    self.send_header('Content-Type', 'image/jpeg')
                    self.send_header('Content-Length', len(frame))
                    self.end_headers()
                    self.wfile.write(frame)
                    self.wfile.write(b'\r\n')
            except Exception as e:
                logging.warning(
                    'Removed streaming client %s: %s',
                    self.client_address, str(e))
        else:
            self.send_error(404)
            self.end_headers()
class StreamingServer(socketserver.ThreadingMixIn, server.HTTPServer):
    allow_reuse_address = True
    daemon_threads = True
with picamera.PiCamera(resolution='320x240', framerate=10) as camera:
    output = StreamingOutput()
    #Uncomment the next line to change your Pi's Camera rotation (in degrees)
    #camera.rotation = 90
    camera.start_recording(output, format='mjpeg')
    try:
        address = ('', 1818)
        server = StreamingServer(address, StreamingHandler)
        server.serve_forever()
    finally:
        camera.stop_recording()
Return to “Camera board”
