TufRat
One Camera, split screen render - center zoom?
Fri Dec 13, 2019 12:19 am
I have been working on a project with the V2 camera board and the Raspberry Pi 4. I need to be able create a digital zoom, and I need two identical renderers. I've got a working zoom. And I've got a working split screen. Copy of the code for both is below. I'm struggling with implementing the zoom demonstrated in the first codeblock within the second codeblock. While I keep at this on my own, I'm hoping someone else can help me. Ultimately, I need to buttons hook two buttons from GPIO to allow a user to zoom in and out.
Center Zoom
from picamera import PiCamera
from picamera import Color
from time import sleep
import time
import numpy as np
import datetime as dt
camera = PiCamera()
camera.rotation = 0
camera.resolution = (3280,2464)
camera.framerate = 60
#camera.video_stabilization = True
camera.start_preview()
camera.preview.rotation = 90
#demonstrate digital zoom
camera.zoom = (0,0,1,1)
print(camera.zoom)
steps = 100
for zf in range(0,95):
    camera.zoom = (zf/(2*steps),zf/(2*steps),1-zf/steps,1-zf/steps)
    sleep(1/steps)
#demonstrate live annotation on live preview pane
camera.annotate_text_size = 64
camera.annotate_foreground = Color('white')
camera.annotate_background = Color('black')
camera.annotate_text = dt.datetime.now().strftime('%Y-%m-%d %H:%M:%S')
start = dt.datetime.now()
while (dt.datetime.now() - start).seconds < 10:
camera.stop_preview()
from picamera import mmalobj as mo, mmal
from signal import pause
camera = mo.MMALCamera()
splitter = mo.MMALSplitter()
render_l = mo.MMALRenderer()
render_r = mo.MMALRenderer()
camera.outputs[0].framesize = (1080, 960)
camera.outputs[0].framerate = 30
camera.outputs[0].commit()
p = render_l.inputs[0].params[mmal.MMAL_PARAMETER_DISPLAYREGION]
p.set = mmal.MMAL_DISPLAY_SET_FULLSCREEN | mmal.MMAL_DISPLAY_SET_DEST_RECT
p.fullscreen = False
p.dest_rect = mmal.MMAL_RECT_T(0, 0, 1080, 960)
render_l.inputs[0].params[mmal.MMAL_PARAMETER_DISPLAYREGION] = p
p.dest_rect = mmal.MMAL_RECT_T(0, 960, 1080, 960)
render_r.inputs[0].params[mmal.MMAL_PARAMETER_DISPLAYREGION] = p
splitter.connect(camera.outputs[0])
render_l.connect(splitter.outputs[0])
render_r.connect(splitter.outputs[1])
splitter.enable()
render_l.enable()
render_r.enable()
HermannSW
Re: One Camera, split screen render - center zoom?
Sun Dec 22, 2019 11:15 am
Center Zoom
import time
import numpy as np
camera = PiCamera()
camera.rotation = 0
print(camera.zoom)
steps = 100
    sleep(1/steps)
I tried your center code, did run out of resources on Pi3B with v2 camera.
So I went to mode 7 and commented out preview rotation:
[email protected]:~ $ diff pic_center.orig pic_center
11c11
< camera.resolution = (3280,2464)
> camera.resolution = (640,480)
17c17
< camera.preview.rotation = 90
> #camera.preview.rotation = 90
I see what the "camera.zoom" is intended to do, but it simply does not work.
The overlayed time did increment every second.
But the whole time the same view is shown (I started "python pic_center").
Please tell how to get digital center working.
P.:S
I just remembered that I used @ethanol100's picamera zoom code back in January successfully.
Will have a look into the differences to your code:
https://www.raspberrypi.org/forums/view ... 4#p1417423
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
TufRat
Thu Jan 02, 2020 4:35 pm
I've just been running it from thonnyIDE as is. IIRC, it only works when plugged into HDMI0.
Return to “Camera board”
