Church Lenard
Image Overlay OpenCV
Sat Nov 16, 2019 1:27 am
ok so ive successfully installed opencv but i cant find a open source code to finalize my project.
Basically im trying to make a pair of nv goggles/sniper scope with an overlay.
can anyone help me?
HermannSW
Re: Image Overlay OpenCV
Sat Nov 16, 2019 4:43 am
C++: https://answers.opencv.org/question/187 ... -opencv-c/
Python: https://stackoverflow.com/questions/140 ... 4#14102014
P.S:
I already have alpha blending sample in my "bash i420toh264 pipeline" for on the fly Raspberry video processing while recording:
https://github.com/Hermann-SW2/userland ... a-blending
Overlaying image is not that difficult there too, just has to be split over the Y, U and V blocks.
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
Church Lenard
Sat Nov 16, 2019 4:57 am
P.S:
This isn't really what i meant since those just seem to overlay on a static image and the others use either a face tracking feature or its tracking a plane but what i meant was to just overlay the image using the live camera feed and have it just boot to the script upon activation.
HermannSW
Sat Nov 16, 2019 6:18 am
I am sure that can be done in OpenCV, though OpenCV will add latency to the video stream.
I just added reticle example (fine crosshair) to (high performance) "bash i420toh264 pipeline" repo.
Fine crosshair will be overlaid onto every frame and is part of GPU generated .h264 video:
https://github.com/Hermann-SW2/userland ... nt-reticle
All that is needed to use your Reticle.jpg is to store it as .pgm image:
$ echo -e "P5\n1640 922\n255\n" >white.pgm
$ head --bytes $((1640*922)) /dev/zero | sed "s/\x00/\xFF/g" >>white.pgm
$ jpegtopnm Reticle.jpg > Reticle.pnm
jpegtopnm: WRITING PPM FILE
$ pnmcomp -align=center -valign=middle Reticle.pnm white.pgm | ppmtopgm > Reticle.pgm
If you store the generated .h264 video into a named pipe, you could use "/opt/vc/src/hello_pi/hello_video/hello_video.bin" to play live video with reticle overlay on monitor:
Church Lenard
Sat Nov 16, 2019 8:06 am
OK ill try that tomorrow as it is 2:30 am where i am ill let you know how it goes
Church Lenard
Sat Nov 16, 2019 5:33 pm
for the execution part it sais "no such file or directory" for./i420toh264
6by9
Sat Nov 16, 2019 5:41 pm
Do you need the overlay on an encoded stream of some form, or just on the HDMI display?
If the latter then just add an extra overlay using either the DispmanX API, or MMAL video_render component. PiCamera provides a simple API for adding an extra overlay, and should work even if you're not using PiCamera for driving the camera. See https://picamera.readthedocs.io/en/late ... he-preview for details.
Church Lenard
Sat Nov 16, 2019 5:59 pm
just tried the sample codes they had and neither would draw or display anything it would only show the camera feed.
also im just trying to make a overlay script that doesn't record or capture images just shows the camera feed with the overlay on an hdmi lcd screen
gordon77
Sat Nov 16, 2019 6:37 pm
Are you trying to do the same as previously?
https://www.raspberrypi.org/forums/view ... p?t=239466
Church Lenard
Sat Nov 16, 2019 6:47 pm
correct but i had thought that topic had died out since it took me almost a year to compile opencv and it turns out the make -j4 command was the culprit
Return to “Camera board”
