Hi
I'm using Picamera 1.13 and have a UI made of overlays. According the documentation it should be possible to change the layer and alpha to hide and show overlays.
Changing the layer works perfectly fine, but setting alpha to 0 on the same overlay does nothing. It does seem to work fine if I try to make a minimal repro, which is strange. But in my app it stays visible. When I print the alpha value I can see it's 0, yet it's fully opaque.
Has anyone encountered a similar issue before or are there known issues related to setting alpha?
Regards
Stan
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
Re: Picamera setting alpha for overlays not working
What format are you passing for your overlay? RGB, or RGBA?
Previously formats that supported per pixel alpha didn't take global alpha, but there is an option to apply both of them. I suspect that PiCamera may not be setting that further flag.
Good point. My overlays are indeed RGBA. I'll try with RGB ones later this week and let you know if they do work fine.
Moving layers around would work fine for my application BTW (though a bit less convenient), just found it curious that alpha was not working.
If setting it from the MMAL layer then you want to add the MMAL_DISPLAY_ALPHA_FLAGS_MIX flag to the alpha value.
If PiCamera is just passing the value through, then you may be able to set the alpha to your desired level + (1<<31) (2147483648 decimal). I suspect it won't work due to https://github.com/waveform80/picamera/ ... rs.py#L116 checking the range for your alpha parameter.
Yep I can confirm that it works fine for RGB layers, but not for RGBA layers.
My alpha level set to the layer is within the range, but I think this check is the problem.
It's probably easiest to use the other approach of moving layers up and down to work around this.
Thanks!
Thanks!
That appears to be a documentation note, not a check.Stannieman wrote: ↑Sat Nov 23, 2019 2:01 pmYep I can confirm that it works fine for RGB layers, but not for RGBA layers.
I've already pointed you at the range limit for aloha. Remove that, and you should be able to add in the ALPHA_FLAGS_MIX flag to allow both per pixel and global alpha.
