Sinamics
[Buster] USB camera, Internal data stream error
Fri Aug 30, 2019 8:16 pm
Spec
  • Raspberry Pi 3 Model B Rev 1.2
    Raspbian Buster Lite, Linux raspberrypi 4.19.69-v7+
    gstreamer 1.14
    Tested with USB Logitech C920 and USB TRUST TRINO 720p
Problem
When upgrading from stretch to buster image the gstreamer pipeline fails with Internal data stream error
I have tried several diffrent pipelines but they all fails with the same error. Seems like some sort of conflict in Buster image.
dmesg log reveals the cannot get freq at ep 0x84 error and i belive this might be the root cause.
Both Stretch Lite and Desktop works like a charm.
Pipeline used for this example
gst-launch-1.0 -v -e --gst-debug=v4l2src:5 v4l2src device=/dev/video0 ! queue ! video/x-h264,width=1280,height=720,framerate=30/1 ! h264parse ! omxh264dec ! udpsink sync=false
Error message (--gst-debug=v4l2src:5)
Setting pipeline to PLAYING ...
New clock: GstSystemClock
0:00:00.286012635 16375  0x1002f50 DEBUG                v4l2src gstv4l2src.c:520:gst_v4l2src_negotiate:<v4l2src0> caps of peer: video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)15/1, format=(string)I420; video/x-raw, width=(int)640, height=(int)480, framerate=(fraction)15/1, format=(string)NV12
0:00:00.286246332 16375  0x1002f50 DEBUG                v4l2src gstv4l2src.c:526:gst_v4l2src_negotiate:<v4l2src0> intersect: EMPTY
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.001050311
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
dmesg log
2724.283426] usb 1-1.3: USB disconnect, device number 8
[ 2725.307493] usb 1-1.4: USB disconnect, device number 5
[ 2727.390400] usb 1-1.2: new high-speed USB device number 9 using dwc_otg
[ 2727.611162] usb 1-1.2: New USB device found, idVendor=0c45, idProduct=6340, bcdDevice= 0.00
[ 2727.611176] usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2727.611186] usb 1-1.2: Product: USB 2.0 Camera
[ 2727.611195] usb 1-1.2: Manufacturer: Sonix Technology Co., Ltd.
[ 2727.616148] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (0c45:6340)
[ 2727.637411] uvcvideo 1-1.2:1.0: Entity type for entity Extension 4 was not initialized!
[ 2727.637429] uvcvideo 1-1.2:1.0: Entity type for entity Processing 3 was not initialized!
[ 2727.637441] uvcvideo 1-1.2:1.0: Entity type for entity Camera 1 was not initialized!
[ 2727.637820] input: USB 2.0 Camera: HD 720P Webcam as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input4
[ 2727.647744] usb 1-1.2: 3:1: cannot get freq at ep 0x84
lsusb
[email protected]:/home/pi# lsusb
Bus 001 Device 009: ID 0c45:6340 Microdia Camera
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
ls /dev/vi*
/dev/video0  /dev/video1  /dev/video10  /dev/video11  /dev/video12
Any advice is highly appreciated.
HermannSW
Re: [Buster] USB camera cannot get freq at ep 0x84
Fri Aug 30, 2019 8:45 pm
Did you start from a scratch installed Buster, or did you dist-upgrade somehow?
I read somewhere that Buster should be/needs to be installed from scratch ...
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
Sinamics
Fri Aug 30, 2019 10:23 pm
I did a clean install from scratch.
I also tried rpi-update, but problem remains.
Sinamics
Re: [Buster] USB camera, Internal data stream error
Sat Aug 31, 2019 7:42 am
I noticed there is a discrepancies between Buster and Stretch v4ctl compliance.
Could this cause any trouble?
Is there anyone else using v4l2 / gstreamer and USB camera with Buster ?
Buster
[email protected]:/home/pi# v4l2-compliance | grep FAIL
        test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: FAIL
        test VIDIOC_QUERYCTRL: FAIL
        test VIDIOC_G/S_PARM: FAIL
        test VIDIOC_G_FMT: FAIL
        Total: 44, Succeeded: 40, Failed: 4, Warnings: 2
Stretch
v4l2-compliance
Total: 43, Succeeded: 43, Failed: 0, Warnings: 0
aerialone
Fri Oct 25, 2019 12:20 am
Has anyone figured this out yet I need to use USB composite video with pi4 .
6by9
Fri Oct 25, 2019 9:27 am
@aerialone With Pi4 omxh264dec will fail as it tries to access the legacy 3D driver which doesn't exist. gst-omx needs to be built with either some build flags altered, or patched to not try egl_render. I identified the issue, but not the solution.
@Sinamics Pi3 should be OK. What kernel version are you running on your Stretch install vs that on Buster? uname -a in each case.
In the switch from Stretch to Buster you will have bumped up GStreamer version (1.10 to 1.14), and potentially kernel version (4.14 to 4.19). Which one causes the problem would be the big question. You should be able to use rpi-update on Stretch to upgrade to the same or later kernel as Buster which allows us to exclude one factor from the equation.
