Prayuktibid
How to read picamera hardware information that which type of camera sensor(imx219 or OV5647) is being used in camera mod
Mon Aug 12, 2019 7:47 am
I want to read the camera hardware spec to ensure which type camera sensor (like imx219 or OV5647) is being used in the rPi camera module for camera module v1 & v2.
Is there any method to read that hardware information from the camera module?
HermannSW
Re: How to read picamera hardware information that which type of camera sensor(imx219 or OV5647) is being used in camera
Mon Aug 12, 2019 7:50 pm
camver script determines camera version:
https://www.raspberrypi.org/forums/view ... 9#p1277731
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
HermannSW
Thu Aug 15, 2019 3:03 pm
Store camver script from the pointed to posting and execute, it will output the camera version.
It does so by querying i2cdetect output, v1 camera runs on 0x36, v2 camera on 0x10.
Prayuktibid
Fri Aug 16, 2019 3:08 pm
Thank you very much for your answer and clarification but my main objective is to know which camera sensor is used in that camera module for both v1 & v2. Is this script return the camera sensor name? Normally, the Rpi camera modules are made using two camera sensor either imx219 or OV5647. My objective is to know only the camera sensor name. Than you.
Prayuktibid
Fri Aug 16, 2019 3:26 pm
Yeah, it is true for the raspberry pi official camera module but it's not true for other RPI compatible chines camera module manufacturers. They have written something on their datasheet and given another thing on their camera module. We have seen that mismatching that's why I asked this question.
This code gives a camera sensor name but I am not sure it is giving a true result or not. here the code below.
import picamera
with picamera.PiCamera() as cam:
    print(cam.revision)
6by9
Fri Aug 16, 2019 5:26 pm
V1 is ov5647
V2 is imx219
https://picamera.readthedocs.io/en/rele ... a.revision is valid. It reads the string as returned by the firmware for the sensor driver in use.
Return to “Camera board”
