larrydong
Using ov9281, do I need an extra driver?
Sat Aug 10, 2019 7:59 am
Hi everyone, I want to use a camera by CSI, however the chip is ov9281.
I connected to pi but the pi cannot find the camera, always "supported=1, checked=0".
I am sure that I used the correct port and connected the cable very stable.
I am not sure if there is anything wrong with my PI or camera, or do I need to install a driver?
Thanks.
Re: Using ov9281, do I need an extra driver?
Sat Aug 10, 2019 1:40 pm
That camera will not work on the raspberry pi using the default system.
You will need to use raspiraw and write a driver for that particular camera. This is not easy.
larrydong
Sat Aug 10, 2019 2:11 pm
@jamesh
Thank you so much.
Do you know if there is an exsiting driver aviable? Otherwise, I need to change my camera.
Sat Aug 10, 2019 2:18 pm
@jamesh
Thank you so much.
There is a well supported Official Camera:
https://www.raspberrypi.org/products/camera-module-v2/
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
HermannSW
Sat Aug 10, 2019 3:35 pm
There is an Arducam 1MP monochrome global shutter camera with ov9281 sensor:
https://www.uctronics.com/index.php/ard ... amera.html
The Arducam driver can be found here, and is based on raspiraw. It can do 135fps framerate:
https://github.com/ArduCAM/MIPI_Camera
You can find links to youtube global shutter videos I took with small brother ov7251 (0.3MP) in this posting:
https://www.raspberrypi.org/forums/view ... 3#p1485903
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://twitter.com/HermannSW
6by9
Sat Aug 10, 2019 7:29 pm
There are a couple of potential options for drivers, although none of them totally trivial.
Hermann's already linked to the Arducam product using the same device. IIRC they've made parts of it closed source, which is a touch annoying.
https://www.vision-components.com/filea ... index.html sell a module based on ov9281, and had linked to drivers (I've not checked their website recently for details/source recently)
https://gitlab.incom.co/CM-Shield/andro ... c/ov9281.c is a driver for the device, but for NVidia platforms instead of the standard V4L2 frameworks.
Take https://github.com/raspberrypi/linux/bl ... c/imx258.c or similar and modify the register calls appropriately. You'll then want a device tree overlay to load the right drivers.
Return to “Camera board”
