HermannSW
How to run raspiraw on Pi with 7" DPI display?
Sun Jul 21, 2019 6:41 pm
I did clone latest raspiraw repo on my Pi 3A+:
https://github.com/6by9/raspiraw
Raspberry v1 camera works without issues, as well as v2 camera.
But I cannot get "/dev/i2c*" showing up, and without that raspiraw does not work:
[email protected]:~/raspiraw $ ./camera_i2c
setting GPIO for board revsion: 9020e0
Raspberry Pi3B / Pi3B+ / 3A / 4B(1G/2G/4G)
Set state of 133 to 1
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
I have enabled I2C and Camera in raspi-config.
And have i2c-dev appended here:
[email protected]:~/raspiraw $ tail -3 /etc/modules-load.d/modules.conf
# at boot time, one per line. Lines beginning with "#" are ignored.
i2c-dev
I have this in /boot/config.txt:
[email protected]:~/raspiraw $ grep i2c_vc /boot/config.txt
dtparam=i2c_vc=on
But i2c does not show up under /dev:
[email protected]:~/raspiraw $ ls -l /dev/ | grep i2c
Questions:
  1. Why does raspivid work without issues?
  2. What do I need to do to make Pi 3A+ show /dev/i2c* and/or get raspiraw to work?
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
HermannSW
Re: How to run raspiraw on Pi with 7" DPI display?
Sun Jul 21, 2019 6:48 pm
I did not think on my today's change of display.
Just commented out the 7" DPI display stuff in /boot/config.txt and rebooted:
[email protected]:~ $ tail -8 /boot/config.txt
#dtoverlay=dpi24
#enable_dpi_lcd=1
#display_default_lcd=1
#dpi_group=2
#dpi_mode=87
#dpi_output_format=0x6f005
#hdmi_cvt 1024 600 60 6 0 0 0
Now /dev/i2c* shows up:
[email protected]:~ $ ls -l /dev/i2c*
crw-rw---- 1 root i2c 89, 0 Jul 21 20:44 /dev/i2c-0
crw-rw---- 1 root i2c 89, 1 Jul 21 20:44 /dev/i2c-1
Does that mean I cannot use raspiraw with DPI display in use?
P.S:
I just prepared Pi 3B for vacation and enabled DPI display.
After rebooting there is no match for "/dev/i2c*" as well, but raspivid works fine.
P.P.S:
Perhaps dmesg information can help?
[email protected]:~ $ dmesg | grep -i i2c
[    2.996391] i2c /dev entries driver
[    4.149726] pinctrl-bcm2835 3f200000.gpio: pin gpio0 already requested by leds; cannot claim for 3f205000.i2c
[    4.149744] pinctrl-bcm2835 3f200000.gpio: pin-0 (3f205000.i2c) status -22
[    4.149764] i2c-bcm2835 3f205000.i2c: Error applying setting, reverse things back
[    4.149787] i2c-bcm2835: probe of 3f205000.i2c failed with error -22
[    4.149856] pinctrl-bcm2835 3f200000.gpio: pin gpio2 already requested by leds; cannot claim for 3f804000.i2c
[    4.149866] pinctrl-bcm2835 3f200000.gpio: pin-2 (3f804000.i2c) status -22
[    4.149885] i2c-bcm2835 3f804000.i2c: Error applying setting, reverse things back
[    4.149899] i2c-bcm2835: probe of 3f804000.i2c failed with error -22
P.P.P.S:
The error messages do not appear after commenting out /boot/config.txt lines and rebooting:
[    2.737715] i2c /dev entries driver
6by9
Sun Jul 21, 2019 9:14 pm
You need to tell linux via device tree to use gpios 44&45 for i2c0, rather than let it try to initialise on 0&1 and then use camera_i2c to change it.
Memory says that the i2c0-bcm2708 overlay allows you to change the pin mixing request via dt. Check the readme for details.
Raspivid is all done via the gpu, so it knows to remux the i2c gpios, and has no qualms over changing it underneath Linux's feet.
Return to “Camera board”
