fehlfarbe
picamera stream freezes after a while
Thu Jul 04, 2019 6:46 pm
I'm using Raspbian stretch with kernel 4.19.56, picamera 1.13 and pygame1.9.6 to display the camera livestream in a pygame surface and capture a high-res image on button press.
I created this class to capture low-res images for faster livestream and take high-res images with different splitter port:
class RaspiboothCam(PhotoboothCam):
    def __init__(self, *args, **kwargs):
        super(RaspiboothCam, self).__init__(*args, **kwargs)
        self.lock = Lock()
        self.img = None
        self.camera = None
        self.run_camera = Event()
        self.camera_thread = None
    def init_camera(self):
        import picamera
        self.log.info("Open PiCamera...")
        self.camera = picamera.PiCamera(resolution=(1920, 1080))
        self.camera.hflip = self.flip_h
        self.camera.vflip = self.flip_v
        self.camera.drc_strength = "off"
        self.log.info(self.camera)
        time.sleep(2.0)
        self.camera_thread = Thread(target=self.run)
        self.camera_thread.start()
        return True
    def close(self):
        self.log.info("close camera")
        self.run_camera.set()
        self.camera_thread.join()
        self.camera.close()
    def run(self):
        from picamera.array import PiRGBArray
        i = 0
        raw_preview = PiRGBArray(self.camera, size=(800, 480))
        stream = self.camera.capture_continuous(raw_preview,
                                                format="bgr",
                                                resize=(800, 480),
                                                use_video_port=True)
        for frame in stream:
            self.log.debug("got frame {:d}".format(i))
            self.img = frame.array.copy()
            raw_preview.truncate(0)
            i += 1
            if self.run_camera.is_set():
                self.log.debug("close camera preview")
                break
        stream.close()
    def take_preview_image(self):
        while self.img is None:
            self.log.warning("Waiting for preview image...")
            time.sleep(0.1)
        return self.img
    def take_photo(self):
        img = np.empty((1088, 1920, 3), dtype=np.uint8)
        self.camera.capture(img, 'bgr', use_video_port=True, splitter_port=1)
        return img
My main loop reads preview images with the take_preview_image method and shows them on screen with pygame. But after a while the streaming freezes and I see always the same image on my pygame surface. It seems capture_continuous waits for something. When I press the take_photo button I get a up-to-date image from the camera via splitter port 1 but my preview stream still hangs. When I restart the app I can't even create the camera object. It just hangs at the PiCamera constructor (same if I just start raspivid).
Any suggestions what's wrong?
fehlfarbe
Re: picamera stream freezes after a while
Mon Aug 12, 2019 2:27 pm
Weird, I downgraded to kernel 4.4 via rpi-update and now it doesn't freeze anymore. With kernel >= 4.9 the image freezes after some seconds or minutes.
Return to “Camera board”
