Swiggolas
Text overlay over split screen live preview
Mon Jun 17, 2019 8:16 pm
I would like to put an overlay with some text over the live preview but for some reason it won't really work when i try it with my code. I used a combination of this (https://raspberrypi.stackexchange.com/q ... ed-display) and this (https://hackaday.io/project/12450/logs) code. I came up with the following code, but i can't really see what i did wrong. If you know something please let me know.
Thanks!
import time
import numpy as np
import string
import random
import os
from picamera import mmalobj as mo, mmal
from signal import pause
from PIL import Image, ImageDraw
camera = mo.MMALCamera()
splitter = mo.MMALSplitter()
render_l = mo.MMALRenderer()
render_r = mo.MMALRenderer()
camera.outputs[0].framesize = (320, 480)
camera.outputs[0].framerate = 60
camera.outputs[0].commit()
p = render_l.inputs[0].params[mmal.MMAL_PARAMETER_DISPLAYREGION]
p.set = mmal.MMAL_DISPLAY_SET_FULLSCREEN | mmal.MMAL_DISPLAY_SET_DEST_RECT
p.fullscreen = False
p.dest_rect = mmal.MMAL_RECT_T(0, 0, 320, 480)
render_l.inputs[0].params[mmal.MMAL_PARAMETER_DISPLAYREGION] = p
p.dest_rect = mmal.MMAL_RECT_T(320, 0, 320, 480)
render_r.inputs[0].params[mmal.MMAL_PARAMETER_DISPLAYREGION] = p
splitter.connect(camera.outputs[0])
render_l.connect(splitter.outputs[0])
render_r.connect(splitter.outputs[1])
splitter.enable()
render_l.enable()
render_r.enable()
topText = "Alt: 310m       Spd: 45km/h         Dir: N"
bottomText = "47.6062 N, 122.3321 W   Home: 322m    Rec: 3:22"
topOverlayImage = textOverlayCanvas.copy()
bottomOverlayImage = textOverlayCanvas.copy()
# Attach overlays
topOverlay = camera.add_overlay(topOverlayImage.tobytes(), size=(320,60), layer=5, alpha=128, fullscreen=False, window=(0,0,320,60))
bottomOverlay = camera.add_overlay(bottomOverlayImage.tobytes(), size=(320,60), layer=4, alpha=128, fullscreen=False, window=(320,0,320,60))
try:
      while True:
         drawTopOverlay = ImageDraw.Draw(topOverlayImage)
         drawTopOverlay.text((200, 15), topText, font=font, fill=(0, 0, 0))
         topOverlay.update(topOverlayImage.tobytes())
         drawBottomOverlay = ImageDraw.Draw(bottomOverlayImage)
         drawBottomOverlay.text((150, 20), bottomText, font=font, fill=(0, 0, 0))
         bottomOverlay.update(bottomOverlayImage.tobytes())
         time.sleep(1)
except KeyboardInterrupt:
    camera.remove_overlay(topOverlay)
    camera.remove_overlay(bottomOverlay)
6by9
Re: Text overlay over split screen live preview
Tue Jun 18, 2019 7:53 am
What "doesn't really work"? Please describe the results you do get.
At a guess your layering is wrong, but it would take a fair amount to recreate. You can use "vcgencmd dispmanx_list" to see the list of elements that have been requested to be put on the screen.
gordon77
Tue Jun 18, 2019 8:53 am
I tried the OPs script and firstly it says..
  File "/home/pi/split1.py", line 37, in <module>
NameError: name 'textOverlayCanvas' is not defined
so I added..
# Create empty images to store text overlays
textOverlayCanvas = Image.new("RGB", (320, 60))
textOverlayPixels = textOverlayCanvas.load()
split image appears and then it says...
  File "/home/pi/split1a.py", line 45, in <module>
AttributeError: 'MMALCamera' object has no attribute 'add_overlay'
6by9
Tue Jun 18, 2019 9:19 am
Thanks gordon77. I was expecting errors, hence being reluctant to spend the time trying to run it myself.
add_overlay is a function of the PiCamera class, not MMALCamera https://picamera.readthedocs.io/en/late ... dd_overlay The code for it is trivial though, so a quick copy/paste should cover it.
Return to “Camera board”
