shinagan
Convert MJPEG output to mp4
Sat Jun 15, 2019 6:19 pm
I have a few videos taken at maximum resolution with the camera v2 (3280x2464) that are in MJPEG format due to the h264 limitation to ~ full HD.
What command line tool can I use to convert these MJPEG streams to mp4 format?
Thanks!
HermannSW
Re: Convert MJPEG output to mp4
Sat Jun 15, 2019 9:27 pm
ffmpeg:
https://www.google.com/search?&q=conver ... mmand+line
P.S:
Off topic, I just used ffmpeg to cut out part of twitter video, and gifenc.sh to convert to animated .gif (robot's response is nice):
https://twitter.com/HermannSW/status/11 ... 0042497024
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
shinagan
Sat Jun 15, 2019 10:03 pm
Well I've looked at a few of these answers and nothing has seemed to work so far.
I thought ffmpeg would be the way to go and tried the following:
ffmpeg -i input -c:v libx264 -preset veryslow -crf 18 output.mp4
I get that preset is not known. When I remove it, ffmpeg says
Unknown encoder 'libx264'
I have installed libavcodec-extra57 -> it did not solve the problem. Still unknown.
I'm not sure what ffmpeg options are required to achieve this, if you have had it working would you mind sharing what options you use? Thanks!
HermannSW
Mon Jun 17, 2019 3:49 pm
I tried several of the mjpeg2mp4 solutions and none worked.
Then I went back to gstreamer, and was able to readout and display mjpeg stream from ESP32-CAM module CamWebserver example:
$ gst-launch souphttpsrc location=http://192.168.178.157:81/stream timeout=5 ! jpegdec ! autovideosink
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
So viewing the mjpeg stream is no problem. I know that mp4mux can be used to create .mp4 video, but was not able to get the jpeg decoded stream of frames stored as .mp4, but reading&decoding is done, so you can start from there.
6by9
Mon Jun 17, 2019 4:10 pm
You've said mp4, which is a container format and not a codec. mp4 can hold a huge number of codec formats.
You can put mjpeg into an mp4 container with
ffmpeg -r 15 -i foo.mjpg -c:v copy bar.mp4
Transcode is a much bigger job, and will be very slow at 8MPix resolution on the CPUs.
HermannSW
Tue Jun 18, 2019 7:31 am
Thanks, this works with http mjpeg stream as well (I used wget, maybe there is a direct ffmpeg way to do so as well):
$ ffmpeg -r 15 -i <(wget http://192.168.178.157:81/stream -O -) -c:v copy bar.mp4
Just terminate the recording+conversion with CTRL-C. The .mp4 plays way too fast in totem video player because of missing time stamps.
Return to “Camera board”
