HermannSW
Re: Raspberry v1 camera global (external) shutter videos
Thu Jul 04, 2019 1:57 pm
I am currently working on sub-project "ESP32-CAM ov2640 sensor global external shutter" and created a sub repo already:
https://github.com/Hermann-SW/Raspberry ... aWebServer
The most difficult part after hardware reverse engineering the ov2640 sensor
https://www.esp32.com/viewtopic.php?f=1 ... 4a48842dd5
was to solder a thin cable to flat ribbon cable connector pin10 (those pins are 0.5mm spaced!), which was surprisingly easy to do with using v1 camera as big magnifying glass and look into HDMI monitor only while soldering:
While with Raspberry v1 camera ov5647 sensor I have full control over when to trigger global reset frame and independently to control the shutter time, the ov5647 predecessor sensor ov2640 that I debugged and use has pins A2 and B2 connected. When setting pin10 to high, all lines get reset. When pin10 gets low, readout of image already starts?!?!? I am pretty sure that global external shutter frames can be captured by ov2640 sensor that way, only some lines at top of frame will be "lost" because they have already been read out and sent to ESP32 when the flash actually happens. This is work in progress.
Today I looked something up on aliexpress and unplanned realized that v1 camera clones (Raspberry v1 camera is not sold anymore after v2 appeared in 2016) do cost less than 4$ these days with free shipping(!):
https://www.aliexpress.com/wholesale?Se ... FreeShip=y
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
HermannSW
Tue Jul 16, 2019 3:55 am
It turned out that soldering cable to ESP32-CAM flat ribbon cable connector was not necessary for taking global (external) shutter frames with ov2640 sensor. Instead ov2640 sensor allows for:
  • some kind of "implicit" global shutter mode
  • global shutter capturing at daylight without external shutter
  • mixed mode global+rolling shutter frames
I added new section "TODOs+ideas" to github repo, also related to Raspberry cameras; for now:
https://github.com/Hermann-SW/Raspberry ... todosideas
TODOs+ideas
  • fully understand how+why (implicit) global shutter capturing for ov2640 works without being triggered explicitely
  • Raspberry v1 camera ov5647 is successor of ov2640; does it have an implicit global shutter mode as well?
  • Raspberry v2 camera Sony imx219 sensor is different; does it allow for implicit global shutter capturing as well?
mkirk
Wed Jul 31, 2019 3:55 pm
The datasheet for the OV5647 states that it supports both rolling and global shutter modes.
https://cdn.sparkfun.com/datasheets/Dev ... 7_full.pdf
Datasheet feature list on page 5: Shutter: rolling shutter / global shutter
Register SC_CMMN_MISC_CTRL has bit[0] defined as cen_global_o
Is that for global shutter mode?
Is it possible to enable global shutter mode on the Pi V1 camera? What parameter is used?
Or does global shutter require an mechanical shutter to control the light?
6by9
Wed Jul 31, 2019 4:03 pm
There is no true global shutter mode.
A global shutter sensor has two image arrays in the silicon, the first exposed to the light, and the second to take the charge and allow readout. The OV5647 does not have this.
It does allow a global reset, and then readout is triggered the exposure time later. This will behave like a global shutter sensor if you either have a mechanical shutter, or disable any form of illumination at the end of the exposure time. This is the mode that HermannSW has been experimenting with.
HermannSW
Wed Jul 31, 2019 9:17 pm
... or disable any form of illumination at the end of the exposure time. This is the mode that HermannSW has been experimenting with.
Exactly, and I am still surprised how well that worked.
See the images (especially the multiple exposure) frames in this thread or on github:
https://github.com/Hermann-SW/Raspberry ... al_shutter
See lines 22-23 in raspivid_ges tool, it was really surprising to me that two register settings sufficed to force gobal reset mode on ov5647 (v1) sensor:
https://github.com/Hermann-SW/Raspberry ... id_ges#L22
Besides the captured airgun pellets in flight, this is one of my favorite multiple exposure v1 frames (8000eps). The cardbox is not that dark because I took the frame with 1fps framerate video, so total light on cardbox was 8000*9us=72ms per frame:
What is still mysterious to me is why I was able to do global shutter (yes, without external) with ov2640 sensor -- it seems to be some kind of overlay of global shutter frame and rolling shutter frame, but at daylight!?!?!
There are two (0.3MP and 1.0MP) Arducam monochrome global shuuter cameras (<30$) that have the mechanism 6by9 stated. And both can be connected to the Pi CSI-2 connector like v1 and v2 camera:
https://www.raspberrypi.org/forums/view ... 3#p1485903
HermannSW
Sat Aug 10, 2019 10:59 am
I just looked at the 5MP sample for rolling shutter effect I used in Information section of github repo:
https://github.com/Hermann-SW/Raspberry ... troduction
I realized that the image provides the propeller rotation direction.
Camera scans lines from top to bottom.
The inserted horizontal blue line shows that propeller blade moved from right to left above propeller center.
The red horizontal line shows that propeller blade moved from left to right below propeller center.
Therefore the rotation direction is counter clockwise (when looking at the image):
Return to “Camera board”
