HermannSW
Question on yuv I420 to grey conversion
Wed May 22, 2019 11:48 am
In YUV I420 format the full size Y plane is followed by half width/half height U and V planes, leading to 8+4+4 bit per pixel:
https://www.fourcc.org/pixel-format/yuv-i420/
The Y plane is called achromatic plane.
What is disadvantage/advantage of taking just the Y plane and use as grey8 image?
I started with a v1 camera mode 2 raspistill 5MP image.
Then I converted it to yuv i420:
$ ffmpeg -i test.5MP.jpg -s 2592x1944 -pix_fmt yuv420p test.5MP.yuv
Finally I created a grey8 .pgm binary file from that:
$ echo -e "P5\n2592 1944\n255" > test.5MP.pgm
$ head --bytes 5038848 test.5MP.yuv >> test.5MP.pgm
The grey image looks fine for me ... (.pgm does not display in browser, can be viewed in eog or gimp):
https://stamm-wilbrandt.de/en/forum/test.5MP.pgm
https://stamm-wilbrandt.de/en/forum/test.5MP.yuv
https://stamm-wilbrandt.de/en/forum/test.5MP.jpg
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
Re: Question on yuv I420 to grey conversion
Wed May 22, 2019 12:13 pm
None, it is a greyscale image - effectively the pixel intensity. U and V provide the colour information.
It's done all the time when you just want greyscale.
HermannSW
Wed May 22, 2019 4:20 pm
> None,
That surprises me, but your explanation makes sense.
That is cool, since using raspividyuv one can just don't look at U and V and work on width*height Y 8bit grey8 information in
static void callback(MMAL_PORT_T *port, MMAL_BUFFER_HEADER_T *buffer)
without having to deal with raw10 Bayer conversion!
(for feature extraction and eg. robot control)
HermannSW
Tue Jun 11, 2019 9:07 pm
Today I wanted to do grey extraction from raspividyuv video and not from ffmpeg generated .yuv as before.
raspividyuv captures multiple of 16 vertical lines, for mode 1 (1920x1080) that is 1920x1088.
This script extracts that grey image from last frame Y as .pgm binary file:
$ cat yex
#!/bin/bash
echo -e "P5\n1920 1080\n255" > yex.pgm
tail --bytes $((1920*544*3)) $1 | head --bytes $((1920*1080)) >> yex.pgm
This is a sample application:
$ raspividyuv -md 1 -p 10,10,960,540 -t 7100 -fps 1 -pts tst.pts -o tst.yuv
$ ./yex tst.yuv
I used "pnmtopng yex.pgm > yex.pgm.png" to convert to image that can be displayed in browser -- a nice grey image:
HermannSW
Tue Aug 20, 2019 5:53 pm
Looked into "Raspberry Pi Camera Module" documentation yesterday:
https://www.raspberrypi.org/documentati ... /camera.md
If interested only in the Y channel of YUV image, then why transmit U and V at all?
This can be achieved by "raspividyuv" option "--luma / -y".
And by "raspivid" option "--raw-format, -rf" of "grey" in case "--raw, -r" option specifies output file name.
yex script from last posting can be simplified in this case to:
$ cat yex
#!/bin/bash
tail --bytes $((1920*1080)) $1 >> yex.pgm
Processing YUV in gstreamer pipeline via:
... ! "video/x-raw, format=I420, ..." ! ...
becomes simply this for Y only processing:
... ! "video/x-raw, format=gray8, ..." ! ...
HermannSW
Tue Oct 22, 2019 9:49 pm
TIL that for keeping YUV frame format, conversion to grey is done by setting U and V value to 128 for all frame pixels.
While the "YUV to RGB" formula might be oversimplified as 6by9 stated, you can see that setting U=V=128 results in equal R, G and B values, which is grey:
https://www.fourcc.org/fccyvrgb.php
B = 1.164(Y - 16)                   + 2.018(U - 128)
G = 1.164(Y - 16) - 0.813(V - 128) - 0.391(U - 128)
R = 1.164(Y - 16) + 1.596(V - 128)
Return to “Camera board”
