xtal256
How to get lowest latency with PiCamera
Mon May 13, 2019 11:35 am
I have a Raspberry Pi 3 and a Pi camera (specifically, the mini "spy" variant) which captures video and outputs to a HDMI connected LCD screen. I'd like to also save the video to file, but showing it on screen is a must.
I am looking to get the highest framerate and lowest latency possible.
Currently, I use the following setup:
camera = picamera.PiCamera()
camera.exposure_mode = 'sports'  # To reduce motion blur
camera.framerate = 49  # Highest supported by mode 5
camera.start_preview(fullscreen=True)
That framerate is set based on the documentation, which is the highest framerate at a decent resolution (mode 5: 1296x730).
Apparently, the spy camera only comes in a V1 module, not V2. (camera.revision returns 'ov5647').
However, latency is still a big problem. When I swipe my hand in front of the camera, there is a noticeable delay before it shows on the screen. I'd say about 200ms.
Is there any better settings I could use? Might it be possible to get better performance by delving into the picamera's more detailed API, or even MMAL?
I have seen some blogs and tutorials use "picamera.array", but I'm not sure if it would be of any benefit to me.
Has anyone had any experience with this, or have any tips?
thanks
Andyroo
Re: How to get lowest latency with PiCamera
Mon May 13, 2019 1:05 pm
I would have a hunt through the posts of HermannSW via memberlist.php?mode=viewprofile&u=198596
He is the master of high speed photography on the Pi.
Need Pi spray - these things are breeding in my house...
6by9
Mon May 13, 2019 1:34 pm
But not for real-time display. He's capturing the raw Bayer data and post-processing it.
I've been through where any latency comes from numerous times in the past. Memory says I've had frames H264 encoded <120ms from receiving the first line of pixels. Display is generally less than that.
What refresh rate is your monitor in? 30Hz vs 60Hz will be adding an extra 16ms. "tvservice -s"
PiCamera is using MMAL underneath, but it'd be worth running just "raspivid -t 0" as a native C user of MMAL.
xtal256
Tue May 14, 2019 6:32 am
Hi 6by9,
Are you saying that you have made blogs/posts on latency in the past? Could you provide some links?
My monitor is 1920x1080 @ 60Hz. In order to get the Pi to output at the correct mode when the screen is turned off, I have set the following video config (after making sure the monitor supported that mode):
hdmi_group=1
hdmi_mode=16
I will see if "raspivid -t 0" can give better results than the Python code, but I'd really like to use the overlay features of the PiCamera's Python API.
xtal256
Tue May 14, 2019 10:44 am
After reading the doco in more detail, it appears I have been doing it wrong.
I thought that just setting the framerate would be enough for it to detect that it needs to use sensor mode 5. But it may have still been at 1920x1080 resolution and using a different sensor mode.
I have now forced it to use mode 5 like so:
camera = picamera.PiCamera(sensor_mode=5)
#camera.exposure_mode = 'sports'  # To reduce motion blur. Does not seem to make much difference.
and am now seeing much lower latency.
That being said, I am still aiming for the lowest possible. So if anyone has any tips I'd much appreciate it.
xtal256
Mon May 20, 2019 4:28 am
Hi 6by9. I'd like to learn more about latency on the picamera. Could you please link me to some of these discussions you mention? When I search your posts for the term "latency", I get 170 results. Are there any posts in particular that you are thinking of?
Also, a related question. Does the camera preview bypass the CPU and send the captured frames directly to the display using the GPU? Or is it necessary for some processing to happen on the CPU?
6by9
Mon May 20, 2019 9:42 am
https://www.raspberrypi.org/forums/view ... 8#p1179652
https://www.raspberrypi.org/forums/view ... 0#p1004792
xtal256 wrote:Also, a related question. Does the camera preview bypass the CPU and send the captured frames directly to the display using the GPU? Or is it necessary for some processing to happen on the CPU?
Yes. If you read the code for any of the raspicam apps you'll find that it uses a mmal_connection with the MMAL_CONNECTION_FLAG_TUNNELLING flag set between all components. This keeps the connection on the GPU, therefore the ARM doesn't need to get involved.
sblaszak
Mon Jun 24, 2019 7:53 am
Another group that has spent a significant amount of time working on driving down the latency for Raspberry Pi camera streaming is the EZ-Wifibroadcast project. They have created a pretty full featured (and easy to install) system to transmit video over wifi for, primarily, RC vehicle/drone first-person-video (FPV) flying/operation. Last I heard, they had been able to get camera to screen latency down to a little over 100 ms over a wifi connection. Even if what you are doing isn't FPV RC related, it sounds like you may be able to re-purpose their software to your use.
Links:
https://github.com/rodizio1/ez-wifibroadcast/wiki
https://www.rcgroups.com/forums/showthr ... de-easy%21 (this is the original, massive, discussion thread that documents most of the development process)
Regards,
sblaszak
Return to “Camera board”
