Page 1 of 3
Image overlay on live video feed
Posted: Wed May 01, 2019 4:53 pm
by Church Lenard
Hey im a complete Noob to this thing and ive tried following tutorials from opencv and many others but ive only seen them work for photo overlays
What im essentially trying to make is the scope from halo with a png overlay to make it legit but all ive found is photo editing and not live feed editing.
Pls help
Re: Image overlay on live video feed
Posted: Wed May 01, 2019 5:14 pm
by gordon77
Can you show us an example of what it will look like?
Posted: Wed May 01, 2019 6:23 pm
by Church Lenard
https://www.google.com/url?sa=i&source= ... 9016093105
This is the vid of it
He said he used opencv but i cant figure it out
Posted: Wed May 01, 2019 8:01 pm
by gordon77
I think you need to use addweighted..
https://stackoverflow.com/questions/408 ... ther-image
Where your video image will be the background image and the target (overlay) a saved image.
Posted: Thu May 02, 2019 8:28 am
by gordon77
Try this... You need to save the target image below.
#!/usr/bin/env python3
import cv2
import os
import time
# setup pi camera
if os.path.exists('/dev/video0') == False:
  path = 'sudo modprobe bcm2835-v4l2'
  os.system (path)
  time.sleep(1)
path = 'v4l2-ctl --set-ctrl=auto_exposure=0'
os.system (path)
# start video
cam = cv2.VideoCapture(0)
# setup window
winName = "Scope"
cv2.namedWindow(winName)
# read foreground image
foreground = cv2.imread('target.jpg')
while True:
    # take video frame
    ok, img = cam.read()
    # add the 2 images
    added_image = cv2.addWeighted(img,0.9,foreground,0.4,0.2)
    # show image
    cv2.imshow( winName,added_image)
    # wait
    key = cv2.waitKey(10)
    # press Esc to EXIT
    if key == 27:
       cv2.destroyWindow(winName)
       break
Posted: Thu May 02, 2019 10:14 am
by 6by9
OpenCV is a very heavyweight way to go about this if you are only after it for the live feed.
The Pi has compositing hardware (the Hardware Video Scalar, or HVS), which can compose multiple planes with alpha blending as it generates the HDMI (or DPI, DSI, or composite) output. This saves the ARM cores reading back all the image data, modifying the pixels, and then feeding it back to be rendered.
Some access is available via PiCamera, and you'd want format=rgba or format=bgra with add_overlay. IIRC you can nearly directly a PNG into a numpy array, and pass that into add_overlay.
Similar threads
viewtopic.php?p=702598
https://github.com/waveform80/picamera/issues/199
Posted: Thu May 02, 2019 3:47 pm
by Church Lenard
Foreground error
```the operation is neither 'array op array'```
And the list goes on but there is a red light on the camera and a blank window
Posted: Thu May 02, 2019 4:36 pm
by gordon77
Assuming you are running the code l posted can you upload the exact errors.
Have you had the camera working before with opencv?
Did you save image as target.jpg in /home/pi/?
Posted: Thu May 02, 2019 6:53 pm
by Church Lenard
  File "/home/pi/test.py", line 27, in <module>
    added_image = cv2.addWeighted(img, 0.9, foreground, 0.4, 0.2)
cv2.error: Opencv(3.4.4) /home/pi/packaging/opencv-python/opencv/modules/core/src/arithm.cpp:660:
error: (-209: sizes of input arguments do not match) The operationis neither 'array op array' (where arrays have the same size and the same number of channels), nor 'array op scalar', nor 'scalar op array' in functio 'arithm_op'
this is the complete error i get
Posted: Thu May 02, 2019 6:58 pm
by gordon77
Interesting, my system produces video 640*480, and the target.jpg is as well
After the line ' # add the 2 images' add the line 'print (img.shape, foreground.shape)'
And tell us the result.
Posted: Thu May 02, 2019 7:12 pm
by Church Lenard
File "/home/pi/test.pi", in <module>
AtributeError: 'NoneType' object has no attribute 'shape'
i am using the 3b+ 2015 model
Posted: Thu May 02, 2019 7:20 pm
by gordon77
Does your Pi camera work ok?
If you do ls /dev in a terminal does it list video0? Or video1?
Posted: Thu May 02, 2019 7:22 pm
by Church Lenard
i use raspivid and the module runs fine also it lists video0
Posted: Thu May 02, 2019 7:31 pm
by gordon77
Sorry but l don't know what's wrong. I use a pi 3b running full raspbian, and Python3.
Posted: Thu May 02, 2019 7:39 pm
by Church Lenard
is there anything i should try or have i just not installed openCV correctly?
Posted: Thu May 02, 2019 7:47 pm
by gordon77
I used this...
sudo pip3 install opencv-python
sudo apt-get install libcblas-dev
sudo apt-get install libhdf5-dev
sudo apt-get install libhdf5-serial-dev
sudo apt-get install libatlas-base-dev
sudo apt-get install libjasper-dev
sudo apt-get install libqtgui4
sudo apt-get install libqt4-test
Re: Image overlay on live video feed (edit)
Posted: Fri May 03, 2019 3:56 pm
by Church Lenard
Ok redownloaded now its import error on numpy.core.multiarry
Im going to try updating it
K nothing works right now im going to reset everything and start fresh
Posted: Sat Nov 16, 2019 8:30 pm
by Church Lenard
import cv2
import os
import time
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# setup window
winName = "Scope"
while True:
    # take video frame
    # add the 2 images
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
ok so i just ran this again with opencv and heres the error i get:
cv2.error: OpenCV(4.1.2) /home/pi/opencv-4.1.2/modules/core/src/arithm.cpp:663:
error: (-209:Sizes of input arguments do not match) The operation is neither 'array op array'
(where arrays have the same sized and number of channels), nor 'array op scalar', nor 'scalar op array'
in function 'arithm_op'
Posted: Sat Nov 16, 2019 8:45 pm
by gordon77
This appears to be saying the video and the jpg are not the same size.
Posted: Sat Nov 16, 2019 8:47 pm
by Church Lenard
and how exactly do i find the size of the video or is there a way to work around this?
Posted: Sun Nov 17, 2019 9:17 am
by gordon77
This will show you the video size, and set it to 640 x 480...
Also a new mask.
import cv2
import os
import time
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
print (cam.get(3)  , cam.get(4))
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
img2 = cv2.imread('Reticle2.jpg')
img2gray = cv2.cvtColor(img2,cv2.COLOR_BGR2GRAY)
ret, mask = cv2.threshold(img2gray, 10, 255, cv2.THRESH_BINARY)
while True:
    # take video frame
    # add the 2 images
    added_image = cv2.bitwise_and(img,img,mask = mask)
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
and a version with black or white reticle with a click of the mouse...
import cv2
import os
import time
invert_mask = 0
# mouse action
def point(event, x, y, flags, param):
    global invert_mask
    if event == cv2.EVENT_LBUTTONDOWN:
        if invert_mask == 0:
            invert_mask = 1
        else:
            invert_mask = 0
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
print (cam.get(3),cam.get(4))
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
# setup mouse callback
cv2.setMouseCallback('Scope',point)
img3 = (255-img2)
while True:
    # take video frame
    # add the 2 images
    else:
        added_image = cv2.addWeighted(img,0.99,img3,0.7,0.2)
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
Posted: Sun Nov 17, 2019 12:24 pm
by HermannSW
Thank you for this cool and fast updating script!
I tested it, and took a smartphone video.
I had installed OpenCV according this instruction from scratch:
https://www.pyimagesearch.com/2019/09/1 ... an-buster/
All that was needed to execute ovl.py script was:
workon cv
./ovl.py
"gordon77's cool OpenCV live video reticle overlay python scipt"
https://youtu.be/P6bvyHwtIqQ
Posted: Sun Nov 17, 2019 2:20 pm
by gordon77
If you can live with an older version of opencv, which l do, and don't want to do a full build then try..
sudo apt-get install python3-opencv
Posted: Sun Nov 17, 2019 6:31 pm
by Church Lenard
Also a new mask.
import cv2
import os
import time
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
while True:
    # take video frame
    # add the 2 images
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
import cv2
import os
import time
invert_mask = 0
# mouse action
    global invert_mask
            invert_mask = 1
        else:
            invert_mask = 0
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
img3 = (255-img2)
while True:
    # take video frame
    # add the 2 images
    else:
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
For the video size code i get
img2gray = cv2.cvtColor(img,cv2.COLOR_BGR2GRAY)
		error code (-215:Assertion Failed) in function cvtCOLOR
and in the code to switch it from black to white i get
img3 = (255-img2)
TypeError: unsupported operand types for -: 'int' and 'NoneType'
also ive tried downloading those devs that you suggested and since it is version 4.1.2 i cant install them without purging the build
Posted: Sun Nov 17, 2019 7:01 pm
by gordon77
Is the camera working? The error message could suggest there is nothing in img. This may also explain your earlier problem.
Did it print a size?
Did you save the reticle as Reticle2.jpg?
If you do ls /dev do you see Video0?
