Church Lenard
Re: Image overlay on live video feed
Fri Nov 22, 2019 1:22 am
gordon77 wrote:
Thu Nov 21, 2019 9:20 am
You could change your monitor to 640x480.
Assuming you are using the GUI..
Choose Preferences from Menu
Choose Screen Configuration
Choose Screens
Choose HDMI-1
Choose Resolution
Choose 640x480
Click on the Green Tick
Choose OK
I did but the image is tiny its like maybe 30% of the screen id upload a pic but it keeps saying the file is too large
gordon77
Fri Nov 22, 2019 8:22 am
Did you include
cv2.namedWindow(winName, cv2.WND_PROP_FULLSCREEN)
cv2.setWindowProperty(winName, cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_FULLSCREEN)
#!/usr/bin/env python3
import cv2
import os
invert_mask = 0
# mouse action
def point(event, x, y, flags, param):
    global invert_mask
    if event == cv2.EVENT_LBUTTONDOWN:
        if invert_mask == 0:
            invert_mask = 1
        else:
            invert_mask = 0
# setup pi camera
if os.path.exists('/dev/video0') == False:
  path = 'sudo modprobe bcm2835-v4l2'
  os.system (path)
  time.sleep(1)
path = 'v4l2-ctl --set-ctrl=auto_exposure=0'
os.system (path)
# start video
cam = cv2.VideoCapture(0)
# show video size
print (cam.get(3),cam.get(4))
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
cv2.namedWindow(winName,cv2.WND_PROP_FULLSCREEN)
cv2.setWindowProperty(winName, cv2.WND_PROP_FULLSCREEN,cv2.WINDOW_FULLSCREEN)
# setup mouse callback
cv2.setMouseCallback('Scope',point)
# read foreground image
img2 = cv2.imread('Reticle2.jpg')
img3 = (255-img2)
img2gray = cv2.cvtColor(img2,cv2.COLOR_BGR2GRAY)
ret, mask = cv2.threshold(img2gray, 10, 255, cv2.THRESH_BINARY)
while True:
    # take video frame
    ok, img = cam.read()
    # add the 2 images
        added_image = cv2.bitwise_and(img,img,mask = mask)
    else:
        added_image = cv2.addWeighted(img,0.99,img3,0.7,0.2)
    # show image
    cv2.imshow( winName,added_image)
    # wait
    key = cv2.waitKey(10)
    # press Esc to EXIT
    if key == 27:
       cv2.destroyWindow(winName)
       break
Church Lenard
Fri Nov 22, 2019 2:44 pm
Did you include
import cv2
import os
invert_mask = 0
# mouse action
    global invert_mask
            invert_mask = 1
        else:
            invert_mask = 0
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
img3 = (255-img2)
while True:
    # take video frame
    # add the 2 images
    else:
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
Yes and i even tested it with the code you had and its still small it is fullscreen and you can see the image but the image is small
gordon77
Fri Nov 22, 2019 2:57 pm
Well I'm baffled as it works on my Pi4.
upload your code as a final check
Church Lenard
Fri Nov 22, 2019 3:11 pm
import cv2
import os
invert_mask = 0
# mouse action
    global invert_mask
            invert_mask = 1
        else:
            invert_mask = 0
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
img3 = (255-img2)
while True:
    # take video frame
    # add the 2 images
    else:
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
im on a pi 3b and using a 3.5 inch waveshare hdmi screen
gordon77
Fri Nov 22, 2019 3:41 pm
Well that's different. What resolution is the screen?
is it hdmi ?
Church Lenard
Fri Nov 22, 2019 3:58 pm
is it hdmi ?
Its hdmi at 640x480
gordon77
Fri Nov 22, 2019 4:09 pm
Can you provide a screenshot using cv2.namedWindow(winName), ie NO FULLSCREEN, does the image fill the screen ?
gordon77
Sun Nov 24, 2019 10:57 am
This version will capture a screenshot when you right click the mouse.
It will also work upto 40fps, (I still haven't worked out why the original didn't !), and allow you to set camera parameters.
Note some camera parameters are interactive, for example if you set high fps you can't set AEB.
import cv2
import time
import os
invert_mask = 0
# mouse action
    global invert_mask
    # Left mouse click to change mask
            invert_mask = 1
        else:
            invert_mask = 0
    # Right mouse click to save screenshot
    if event == cv2.EVENT_RBUTTONDOWN:
        path = 'scrot screenshot.jpg'
        os.system (path)
# set video size
cam.set(3,640)
cam.set(4,480)
  os.system (path)
  time.sleep(1)
FPS          = 40
AutoExp      = 0   # 0 = auto ON , 1 = auto OFF
AEB          = 12  # range 0 - 24
ExpTime      = 1000
brightness   = 60
ISO          = 0   # 0 = auto, 1 = 100, 2 = 200 etc
contrast     = 50
scene        = 8   # 0 = normal, 8 = night, 11 = sports
saturation   = 25
red_balance  = 1188
blue_balance = 1228
winName = "Scope"
cv2.namedWindow(winName)#
#cv2.namedWindow(winName,cv2.WINDOW_GUI_NORMAL)
#cv2.setWindowProperty(winName,cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_FULLSCREEN)
# setup camera
path = 'v4l2-ctl --set-ctrl=brightness=' + str(brightness)
os.system (path)
path = 'v4l2-ctl --set-ctrl=contrast=' + str(contrast)
os.system (path)
if AutoExp == 0:
  os.system (path)
  path = 'v4l2-ctl --set-ctrl=auto_exposure_bias=' + str(AEB)
  os.system (path)
else:
  path = 'v4l2-ctl --set-ctrl=auto_exposure=1'
  os.system (path)
  if AutoExp == 1:
    path = 'v4l2-ctl --set-ctrl=exposure_time_absolute=' + str(ExpTime)
    os.system (path)
if ISO == 0:
   path = 'v4l2-ctl --set-ctrl=iso_sensitivity_auto=1'
   os.system (path)
else:
   path = 'v4l2-ctl --set-ctrl=iso_sensitivity_auto=0'
   os.system (path)
path = 'v4l2-ctl --set-ctrl=iso_sensitivity=' + str(ISO)
os.system (path)
os.system (path)
path = 'v4l2-ctl -p ' + str(FPS)
os.system (path)
path = 'v4l2-ctl --set-ctrl=scene_mode=' + str(scene)
os.system (path)
path = "v4l2-ctl -c white_balance_auto_preset=0"
os.system (path)
path = "v4l2-ctl -c red_balance=" + str(red_balance)
os.system (path)
path = "v4l2-ctl -c blue_balance=" + str(blue_balance)
os.system (path)
path = "v4l2-ctl -c sharpness=50"
os.system (path)
path = "v4l2-ctl -c saturation=" + str(saturation)
os.system (path)
img3 = (255-img2)
while True:
     else:
     if key == 27:
        break
print ("Goodbye")
Church Lenard
Sun Nov 24, 2019 9:10 pm
I would provide a screenshot but it wont take the images that im taking but the image does seem adequate for the windowed size
Return to “Camera board”
