inac
rawcam and corrupted trailer
Mon Feb 18, 2019 4:46 pm
I’m trying to get my custom camera to work. The path I use is [rawcam] -> [isp] -> [image_encoder]. RAW12
My port parameters are
*************** Port parameters ***************
CAM Out                                        ->  [  ISP In      -   ISP out  ]  ->  [ Encoder In    - Encoder out  ]
type                                   OUTPUT  ->       INPUT     -      OUTPUT   ->        INPUT     -     OUTPUT
enabled                                    1   ->           1     -           1   ->            1     -          1
format->type                               3   ->           3     -           3   ->            3     -          3
format->encoding                        pR12   ->        pR12     -        I420   ->         I420     -       JPEG
format->es->video->width                3968   ->        3968     -        3968   ->         3968     -          0
format->es->video->height               3040   ->        3040     -        3040   ->         3040     -          0
format->es->video->crop->width          3968   ->        3968     -        3968   ->         3968     -          0
format->es->video->crop->height         3040   ->        3040     -        3040   ->         3040     -          0
format->extradata_size                     0   ->           0     -           0   ->            0     -          0
format->extradata                          0   ->           0     -           0   ->            0     -          0
buffer_num                                 4   ->           4     -           1   ->            1     -          1
buffer_size                         18094080   ->    18094080     -    18094080   ->     18094080     -   12062720
buffer_num_min                             4   ->           1     -           1   ->            1     -          1
buffer_size_min                     18094080   ->    18094080     -    18094080   ->     18094080     -   12062720
buffer_num_recommended                     4   ->           1     -           1   ->            1     -          1
buffer_size_recommended             18094080   ->    18094080     -    18094080   ->     18094080     -   12062720
The path is giving correct images but it crashes. When I look at the
sudo /opt/vc/bin/vcdbg reloc
I get a corrupt trailer.
Relocatable heap version 4 found at 0x20000000
total space allocated is 492M, with 492M relocatable, 0 legacy and 0 offline
0 legacy blocks of size 2359296
free list at 0x3ebffda0
439M free memory in 2 free block(s)
largest free block is 439M bytes
0x20000000: free 439M
[   8] 0x3b6b2480: used  17M (refcount 0 lock count 0, size 18094080, align   32, data 0x3b6b24a0, d1rual) 'ril.rawcam:out:0(pR12)'
0x3b6b2480: corrupt trailer (space 1431655680 != 18094145)
0x3c7f3cc0: corrupt entry (space 0x55edbd55)
resynced at 0x3ebeed60 (skipped 37728416 bytes)
[   2] 0x3ebeed60: used  16K (refcount 1 lock count 0, size    16384, align   32, data 0x3ebeed80, d0ruAl) 'audioplus_tmp_buf'
[   1] 0x3ebf2da0: used 4.0K (refcount 1 lock count 0, size        0, align 4096, data 0x3ebf3000, d1rual) 'camera fast alloc arena'
[   3] 0x3ebf3dc0: used  47K (refcount 1 lock count 0, size    48483, align    1, data 0x3ebf3de0, d0rual) 'dt_blob'
0x3ebffb80: free 576
[   5] 0x3ebffdc0: used  576 (refcount 1 lock count 0, size      512, align    4, data 0x3ebffde0, d0rual) 'ILCS VC buffer pool'
heap corruption detected
small allocs not requested
When I only comment out the following line
    output->format->es->video.crop.width = roi.width;
    output->format->es->video.crop.height = roi.height;
    //output->format->es->video.width = VCOS_ALIGN_UP(roi.width, 16);
    output->format->es->video.height = VCOS_ALIGN_UP(roi.height, 16);
I get strange port parameters at the video->width.
format->es->video->width                   0   ->           0     -        3968   ->         3968     -          0
buffer_size_min                            0   ->    18094080     -    18094080   ->     18094080     -   12062720
buffer_size_recommended                    0   ->    18094080     -    18094080   ->     18094080     -   12062720
And reboot the RPi. Then running the program again the corrupted trailer is gone.
490M free memory in 2 free block(s)
largest free block is 490M bytes
0x20000000: free 490M
[   4] 0x3ea76d40: used 1.5M (refcount 1 lock count 8, size  1536000, align 4096, data 0x3ea77000, d1rual) 'ARM FB'
But I get empty black images.
Why is this happening and how can I debug?
6by9
Re: rawcam and corrupted trailer
Tue Feb 19, 2019 2:11 pm
The CSI2 receiver peripheral takes a start and an end address, so should never exceed those bounds. Indeed it can work in a circular buffer mode where it'll return back to the start should the amount of data exceed the buffer size - that mode hasn't been tested for a VERY long time, so I couldn't say whether it reliably works. It's not used with rawcam anyway as we only signal when the whole buffer is complete.
In your "normal" situation, I'd say that the CSI2 source is sending more than 3040 lines of data, and it is managing to overflow the buffer. Add a couple of lines to format->es->video->height and it'll probably be happy as you've added padding to the buffer should it overrun.
The frame is signalled as "complete" when the "frame end" short packet is received on the CSI2 bus, therefore it doesn't actually matter what format->es->video->[crop.]height are set to beyond setting up buffer sizes and telling downstream components.
Setting output->format->es->video.width to 0 is a nonsense configuration, and I'm surprised it allowed you to in the mmal_port_format_commit.
You've set the stride (the address increment between one line to the next) to 0, therefore it'll start writing line 1 to memory at the start of the buffer, and then increment so line 2 starts at "start + 1*stride", which is still start if stride = 0. I suspect that the first line of your "black" image has data in it, and then the rest is uninitialised and happens to be 0.
inac
Wed Feb 27, 2019 3:49 pm
Thanks! That give a nice view what's going on. Apparently the camera gives a few lines more out than we set.
Return to “Camera board”
