Camera V2.1 not (or no longer) working on Pi Zero W
Posted: Wed Jan 30, 2019 4:43 am
by Doub
I've been playing with cameras on a Pi Zero W for a while, and I recently purchased a NoIR Camera V2.1, which worked for a few days. I manipulated it a bit to test mechanical mounting on my project, and at some point it stopped working. I have two Pi Zero W on hand, and both had the same issue (with the same SD card). I assumed I broke the camera. So I ordered a couple others (this time the regular variant instead of the NoIR). And they didn't work either. So maybe I had broken the OS on the SD card, and I installed a fresh Raspbian on another SD card, but the result is the same. What's puzzling me is that all my cameras V1 (one official, a bunch of chinese clones) still work.
Here's some checks I did from other threads:
[email protected]:~ $ vcgencmd otp_dump |grep ^30
30:009000c1
[email protected]:~ $ cat /proc/cpuinfo | grep Revision
Revision        : 9000c1
[email protected]:~ $ sudo rpi-update
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
 *** Your firmware is already up to date
[email protected]:~ $ sudo raspistill -o tmp.jpg
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
[email protected]:~ $ raspistill -t 1000
[email protected]:~ $ sudo vcdbg log assert
No messages available
Here is my cmdline.txt:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait fastboot noswap ro
Here is my config.txt (with the comments and commented-out lines stripped):
disable_overscan=1
hdmi_force_hotplug=1
hdmi_group=1
hdmi_mode=4
dtparam=audio=on
dtoverlay=dwc2
start_x=1
gpu_mem=256
dtdebug=1
As you can see I increased the gpu_mem. I started with 128, went to 144, then 256. No value improved the situation.
I'm out of ideas. What else can I do to try to fix the situation?
Re: Camera V2.1 not (or no longer) working on Pi Zero W
Posted: Thu Jan 31, 2019 1:14 am
by wh7qq
There have been a number of posts here on the fragility of the camera connector on the RPi Zero...any variant...due to its small size and delicacy. That is the most likely scenario for your problem. If the tiny black locking bar is still intact, you might try using a small bit of transparent tape on the non-contact side of the ribbon connector to increase its thickness and check it out with basic camera commands. If broken, as mine was, putting the ribbon in first, then inserting the black bar and holding it while (carefully) applying hot melt adhesive was the solution for me. In either case, the adhesive is the final answer.
Posted: Fri Feb 01, 2019 4:01 pm
by Doub
But the cameras v1 are still working. Wouldn't a broken connector affect all cameras equally?
Posted: Fri Feb 01, 2019 7:11 pm
by HermannSW
Yes.
What is the output of "vcgencmd get_camera" with v2 camera connected?
Posted: Fri Feb 01, 2019 9:16 pm
by Doub
Here is what I get with one of the non-working V2 cameras.
[email protected]:~ $ vcgencmd get_camera
supported=1 detected=1
[email protected]:~ $ raspivid -f
But I've got some good news. Waiting for suggestions I ordered another Pi Zero W and another NoIR camera V2, and they worked together out of the box. I also received the cloned IMX219 modules I ordered from China a while back, and it worked on my original NoIR intermediate PCB. I took some pictures of the V2 cameras I have. Front:
And back:
So here's what's broken:
- A + A'
- B
- B + E
- C
- C + E
And here's what's working:
- A + E
- D
- D + E
So obviously I broke the A' flex PCB (I forcefully removed the lens and then bent the flex PCB too much, it's on me). But I don't understand what's wrong with B and C. The only obvious differences are:
- the PCB color
- the week code for the green ones is two years older than the NoIR ones
- B and C have a different crystal: it's in a black epoxy package, where A and D have a more common metal case crystal
- only A has a "PASS" holographic sticker
- they all have different Data Matrix stickers
- D didn't come in a box, but all 3 other boxes look similar and legit
Are B and C possibly fakes? Or did they pass their shelf life? Let me know if you want me to test anything before I return B and C to Amazon.
