msaiducar
raspivid doesn't include b-frames
Wed Jan 16, 2019 12:15 pm
Hi all,
I'm streaming raw h264 using raspivid on Raspberry Pi 3 and PiCam v1 . However, even I set the h264 profile to main or high, stream only contains I and P frames. Here is the command that I use for starting stream over TCP;
raspivid --verbose --framerate 10 -b 1000000 --stats --intra 50 --inline --nopreview  -t 0 -l --output tcp://0.0.0.0:5001
When I parse the byte stream, I only see SPS,PPS,I-frames and P-frames. How can I make raspivid to add B-frames also?
6by9
Re: raspivid doesn't include b-frames
Wed Jan 16, 2019 12:31 pm
You can't. The hardware encoder doesn't support them.
The profile specifies the feature set that the encoder can use to compress the stream, it doesn't obligate the use of any or all of them.
B-frames significantly increase the complexity of the encoder, partly as it needs to search multiple frames for best motion match, but also that you then have increased and variable latency through the codec as you need all the I or P frames to search before you can start encoding the B frame.
msaiducar
Wed Jan 16, 2019 1:09 pm
That perfectly makes sense. So can I create h264 stream with software encoder and how? Latency and quality of video is not important, I just need to create an application to read h264 stream and parse the I-P-B frames. I only have Raspberry Pi and Pi Camera to create stream.
Wed Jan 16, 2019 1:47 pm
You would need to use the software h264 encoder and turn on everything. ffmeg would do that, or GUI apps like Handbrake. Not sure if that runs on the Pi though, some people have compiled it. Not familiar with other alternatives.
6by9
Wed Jan 16, 2019 1:49 pm
Realtime you'll struggle with at 1080P30 - it's the reason that it is offloaded to hardware.
Lower res or offline compression then ffmpeg or GStreamer can both handle that.
Return to “Camera board”
