How to use imx334 not imx219 work with pi?
Posted: Wed Oct 10, 2018 5:13 pm
I want to use another camera sony imx334 with pi . but I don't know is it possible to do that?if yes,how ?pls !
A small, affordable computer with free resources to help people learn, make things, and have fun
https://www.raspberrypi.org/forums/
https://www.raspberrypi.org/forums/viewtopic.php?f=43&t=224484
Sorry, the only supported camera for the CSI port are the OV5647 and the IMX219.
Thanks, I suspected my data was a bit out of date! Hadan't realised the ISP component had been merged.6by9 wrote: ↑Thu Oct 11, 2018 10:54 am(I'll correct my colleague)
The Linux CSI2 driver allows you to run any sensor you like and write the raw frames into memory.
The sensor driver and all control of the sensor is up to you. imx 258, 274, 319, and 355 drivers all appear to be merged in https://git.linuxtv.org/media_tree.git/ ... /media/i2c and may make reasonable examples for you to then adapt. There are a couple of others being pinged around the linux-media mailing list at the moment, but not imx334.
James is right that there is no access to things like auto exposure, or auto white balance. Again you are responsible for that.
You have got access to the ISP hardware via MMAL and the vc.ril.isp component. That will accept the majority of the formats that are expected (Bayer 8, 10, 12, 14, or 16 bit, YUYV family, RGB 565, 888, and 8888 (with alpha ignored)), and will process as required to produce YUV or RGB output.
Collecting statistics for the image is currently up to you.
There is an example app for how to pass the data around effiiciently in yavta. It started as one of the standard V4L2 test apps, but has gained the relevant integration into MMAL. I've mainly been testing it with sources producing YUYV or RGB formats, so it hasn't got example white balance. I have done that in raspiraw, so might see if I can transplant the code easily.
Almost 18 months ago
