narragansett
please help -- having problems running raspiraw
Thu Aug 16, 2018 3:45 am
I'm having some issues with running raspiraw. I've tried both branches https://github.com/6by9/raspiraw and https://github.com/Hermann-SW/fork-raspiraw.
I have a version 2.1 camera and Raspberry v3 b+.
Here's what i get when running raspiraw on either version:
[email protected]:~/raspiraw $ ./raspiraw -md 7 -t 300 -ts tstamps.csv -hd0 hd0.32k --height 480 --top 0 --vinc 17 --fps 90 -sr 1 -o /dev/shm/out.%04d.raw
Using i2C device /dev/i2c-0
RaspiRaw: Probing sensor ov5647 on addr 36
RaspiRaw: Probing sensor imx219 on addr 10
RaspiRaw: Probing sensor adv7282 on addr 21
RaspiRaw: No sensor found. Aborting
There are some setup steps described here -- viewtopic.php?f=43&t=189661&p=1232058#p1218763 but when I run the camera-i2c utility it get this:
[email protected]:~/userland-rawcam $ sudo ./camera_i2c
setting GPIO for board revsion: a020d3
Failed: don't know how to set GPIO for this board!
It seems that this is an older version of the camera_i2c utility-- perhaps for the v1 camera board? I compiled the latest code from https://github.com/6by9/userland but it doesn't seem to have the camera_i2c utility.
My v2.1 camera board works....
thanks!
6by9
Re: please help -- having problems running raspiraw
Thu Aug 16, 2018 6:25 am
The camera_i2c error would be that a new board revision is now in circulation, and the script doesn't handle it. I'll sort a patch today (6by9/raspiraw only. The userland repo is the old location, and HermannSW 's repo is his to maintain)
narragansett
Thu Aug 16, 2018 12:50 pm
Muchas gracias for the quick reply 6by9!
narragansett
Thu Aug 16, 2018 1:25 pm
I didn't notice the camera_i2c script sitting in the https://github.com/6by9/raspiraw repository (oops!) It runs fine for my camera and so does raspiraw (after running camera_i2c) So, all good....
gracias!
narragansett
Fri Aug 17, 2018 4:29 pm
Thought I'd share my notes --- the updated setup steps for getting raspiraw running
1. Run
sudo apt-get install wiringpi
2. Add the line
dtparam=i2c_vc=on
to the file /boot/config.txt.
3. Add the line
i2c-dev
to the file /etc/modules-load.d/modules.conf.
4. Now reboot.
5. Run these
git clone https://github.com/6by9/raspiraw.git
cd raspiraw
./buildme
6. Add the line
PATH=~/raspiraw:~/raspiraw/tools:$PATH
to your .bashrc file (~/.bashrc)
7. Bring up a new terminal and run these
cd raspiraw
./camera_i2c
raspiraw -md 7 -t 1000 --height 480 --top 0 -sr 1 -g 240 -e 200 --vinc 17 -o /dev/shm/out.%04d.raw
You should get a bunch of raw frames dumped to your /dev/shm directory.
Note, you'll need to run camera_i2c before you run raspiraw upon each reboot.
thanks!
Return to “Camera board”
