airmouse
Reliable RCA (NTSC) Camera input (custom camera)??
Wed Aug 15, 2018 8:24 pm
I have tried a few USB-to-RCA converts and some purely USB webcams but always get errors or weird images. This occurs on various Pi's and OS's. But never any issue for Windows..
We need a more direct/reliable approach and I was wondering if I can somehow solder an RCA jack to the Picamera input port for direct signal input without all the funky converters, or any similar hacks?
I know raspberry pi has a whole assortment of cameras I can pick from but none will work for us, and I require using a specific camera that is NTSC.
Is it possible to hotwire an RCA input (soldering directly to PCB pads/traces)? Or an RCA-to-ribbon cable adapter, Or any USB-to-RCA converts that are guaranteed to just work??
mahjongg
Re: Reliable RCA (NTSC) Camera input (custom camera)??
Wed Aug 15, 2018 8:32 pm
No that is NOT possible, the camera input is digital (serial), and Cannot be directly used to input analog video.
Since shortly a digital interface board that can convert analog video to the RPIs camera signal, but its complicated thus not cheap.
airmouse
Wed Aug 15, 2018 9:00 pm
Thanks, I figured it would not be possible to accomplish directly connecting but thought I'd ask.
Alternatively are there any NTSC-to-USB input capture hardware from specific vendors/chipsets that are fully supported in the latest Rasbian and PI3?
So far we have tried 4 different make/model input modules, but always get errors regarding mp4 codecs (green fuzzy images), or no video input was detected at all..
HermannSW
Thu Aug 16, 2018 12:09 pm
No that is NOT possible, the camera output is digital (serial), and Cannot be directly used to input analog video.
There is DueVGA library that allows a 84MHz only Arduino Due to generate Pal and NTSC output in pure software (and six resistors):
https://stimmer.github.io/DueVGA/
Adding an AD converter to the Pi it should not be that difficult to read the digital NTSC camera signal and display it. I am not aware of such software (inverse of DueVGA) though.
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw      https://github.com/Hermann-SW/userland
https://github.com/Hermann-SW/wireless-control-Eachine-E52-drone      https://twitter.com/HermannSW
6by9
Thu Aug 16, 2018 12:18 pm
The Analog Devices ADV7280-MA and ADV7282-MA chips are analogue video to CSI2 bridge chips (PAL/NTSC/SECAM), and they're now supported. Those two variants both include deinterlacing, which makes life significantly simpler.
AFAIK no one is making a standard add-on board wth either as yet, but a couple of people are posting on here that are using it in their own products.
Analogue TV to USB converters are all a little hit-and-miss on the Pi.
mahjongg
Sun Aug 19, 2018 9:42 pm
That one thing can be done in software does NOT mean the same thing can be done in reverse in software too....
its like encryption, its easy to encrypt a text, its much harder to decrypt it.
likewise its easy to encode a (NTSC) video signal using minimal software and hardware, for example a ZX80 could do it with just a 3.25MHz Z80, and not much more, but its INFINITELY more difficult to capture that video signal, you need extensive hardware and software to do that.
Return to “Camera board”
