gius
wider Hfov lens for 5mp camera module
Mon Jul 23, 2018 11:55 am
Hi all,
I would like to change the lens in my rpi camera module v 1.3.
Anyone could advise me where to buy a lens with a Hfov of about 70 degrees or so (not fisheye)?
What is the lens mount in camera module v 1.3?
Thank you.
Giuseppe
jbeale
Re: wider Hfov lens for 5mp camera module
Wed Jul 25, 2018 11:06 pm
I realize there isn't much info here, but: https://elinux.org/Rpi_Camera_Module#Re ... Stock_Lens
As far as I know there is no drop-in replacement for the tiny (non-standard, M6 ?) lens used in the camera module. Easiest thing to do is simply add an external wide-angle adaptor such as are sold for iPhone etc. Or, remove the lens and add a more-standard M12 lens adaptor with the M12 lens of your choice.
See, for example https://www.lensation.de/product-catego ... nt-lenses/ together with something like
https://www.thingiverse.com/thing:539517
HermannSW
Thu Jul 26, 2018 12:06 pm
I followed jbeale's suggestion, added M12 mounts to v1 as well as v2 camera. Was easy, Details here:
viewtopic.php?f=43&t=45887&p=1298451#p1279957
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw
https://github.com/Hermann-SW/userland
https://twitter.com/HermannSW
gius
Thu Jul 26, 2018 5:48 pm
Thank you all.
Changing mount to m12 is probably the best solution.
I found the module from arducam with a m12 mount and a wider lens Fov:
https://www.amazon.com/Arducam-Megapixe ... 56&sr=1-23
I was also wondering if the lens in camera module v2, with a slightly wider Fov, can fit on 5 mp camera module. Of course it would not be a cheap solution to buy 2 modules. just for changing the lens...
HermannSW
Sat Jul 28, 2018 9:59 pm
You get ov5647 module with M12 lens mount for 9$ on aliexpress with free shipping (search for "night Raspberry camera"). This avoids the "change to M12 mount" part.
I use 2.50$ free shipping 130 degree lens without issues when I need it. I bought many different degree (cheap) lenses and they worked:
https://www.aliexpress.com/item/CCTV-Le ... 23526.html
Hermann.
Return to “Camera board”
