nhantd95
PiCam detection
Tue Jul 17, 2018 6:59 am
Hello guys,
I have a project using PiCam to observe the conveyor in our plant because sometime it was stucked.Is it possible to use PiCam to detect when the conveyor is stucked and stop ? I researched many projects on google but there are only Picam motion detect security system.How about detect "motion stop" ? Thanks guys ! :D
KnarfB
Re: PiCam detection
Thu Jul 19, 2018 1:39 pm
Hi nhantd95,
I would use the OpenCV library and a little C++ programming for that (Python works too). Capture two picturea A and B and compute the sum of pixelwise absolute differences ( norm(A-B) ). If the resulting value is small (in plain theory: 0) the pictures are identical -> no motion. If the difference is larger than some threshold, the pictures differ --> motion.
Finding the thresholds needs some experimentation. You may restrict the area where you are looking for motion by masking the pictures. Varying lighting conditions will it make more difficult to find good thresholds. If you can put marks on the moving parts, this may help.
hth
KnarfB
nospam
Re: PiCam detection
Sun Jul 22, 2018 1:04 pm
It's doable but you would be far better off (ie. cheaper and more robust solution) getting a dedicated industrial belt motion sensor and tie that into your PLC controlling the belt drive.
nhantd95
Re: PiCam detection
Mon Jul 30, 2018 8:27 am
Hi knarfB,
I don't understand your ideas.We have to capture 2 pics in the same motion or different motion ? And I always have to cap 2 pics to compare them to identify which one is motion and no motion ?
KnarfB
Re: PiCam detection
Wed Aug 15, 2018 8:04 am
Hi nhantd95,
sorry for the delayed answer, I was on vacation. You capture a picture A and shortly afterwards another picture B. If A and B are identical --> no motion. If A and B differ --> motion (because something has changed/moved in the scene).
In practice you have to make decisions about the time difference between capturing A and B.
It should be small (to avoid global changes in the scene like sunlight,...) but not too small (depending on the speed of motion).
You have also to decide how to interpret "identical" because A and B will not be exactly the same (because of noise...)
A quick approach is to calculate the norm norm(B-A) and call A and B identical if the norm is below a threshold.
There are also more sophisticated approaches. Search for "motion detection opencv" to get an idea.
hth
KnarfB
PiGraham
Re: PiCam detection
Wed Aug 15, 2018 8:15 am
I agree, this is a much better solution. Any industrial sensor that is triggered by motion of the belt can be used to confirm that the belt is moving.
PiGraham
Re: PiCam detection
Wed Aug 15, 2018 8:22 am
Hello guys,
If you want to detect no motion just keep looking for motion and if you don't find any for some time period signal a no motion alarm.
Bear in mind that an empty section of conveyor that is moving might not be detected as motion because it looks much the same . Also, there may still be motion detected when the conveyor is stopped due to changing lighting, or other changes in the scene e.g. people or machinery moving near the conveyor, flickering screens, blinking lights etc.
I don't think a camera is a good choice for this. Use a more direct and rugged sensor.
RaTTuS
Re: PiCam detection
Wed Aug 15, 2018 8:30 am
possibly you need to look at moition vectors
https://www.raspberrypi.org/blog/vector ... stimation/
Covfefe
Return to “Camera board”
