mfraser
Timelapse
Mon May 14, 2018 4:09 pm
Currently I'm running a Python program to capture an image every 5 minutes and upload a photo on the hour which uses crontab to run every 5 minutes.
As most of the program only needs to be run once I thought about using a loop in Python instead and this is what I have come up with. My concern at the moment is having to use camera.capture twice, is there a better way of saving the same image to 2 places?
Also is there a better way of achieving what I am doing?
#!/usr/bin/env python
import picamera
import time
import tweepy
from datetime import datetime
mydir = '/var/www/'
photo_path = mydir+'webcam.jpg'
# Consumer keys and access tokens, used for OAuth
consumer_key = ''
consumer_secret = ''
access_token = ''
access_token_secret = ''
# OAuth process, using the keys and tokens
auth = tweepy.OAuthHandler(consumer_key, consumer_secret)
auth.set_access_token(access_token, access_token_secret)
# Creation of the actual interface, using authentication
api = tweepy.API(auth)
while True:
    now = datetime.now()
    timeInfo = now.strftime('%d/%m/%y %H.%M')
    timestamp = now.strftime('%H:%M')
    if now.minute % 5 == 0 and now.second <= 10:
        with picamera.PiCamera() as camera:
            camera.resolution = (1280, 1024)
            camera.annotate_background = picamera.Color('black')
            camera.annotate_text = timeInfo
            time.sleep(2)
            # Take a picture including the annotation
            camera.capture(photo_path)
            camera.capture(mydir + 'webcam/webcam' + timestamp + '.jpg')
        if now.minute <= 4:
            status = 'Weather #Yeovil: ' + timeInfo
            api.update_with_media(photo_path, status=status)
        time.sleep(40)
    time.sleep(5)
6by9
Re: Timelapse
Mon May 14, 2018 4:37 pm
Just copy the file? Two seconds with Google gave https://stackoverflow.com/questions/123 ... -in-python
from shutil import copyfile
copyfile(photo_path, mydir + 'webcam/webcam' + timestamp + '.jpg')
mfraser
Re: Timelapse
Sat May 19, 2018 2:33 pm
I had seen copyfile from shutil, but wasn't sure if it was suitable for the job. Now using it.
Many thanks.
Return to “Camera board”
