yds
Lens degradation??
Tue Apr 17, 2018 1:42 am
I've been using my Picam outdoors, in a sheltered location, without any type of cover over the lens, for the past year or so. Lately, the image has seemed blurry and yellowish. Is it possible the lens has been degraded by UVs? Tried cleaning it with Isopropyl alcohol on a Q-tip, in case it was just dirty, but no difference.
Snapshot attached. Taken during cloudy skys, so it less yellowish, but still blurry.
PorchCam 2018-4-17 07.11.24.379 AM.jpg (175.76 KiB) Viewed 1278 times
jit
Re: Lens degradation??
Thu Apr 19, 2018 6:16 am
I've recently experienced something similar to this myself. Was wondering if the sensor may have been damaged or maybe the lense out of place causing the focus to be off.
Thu Apr 19, 2018 6:19 am
Hmm. I don;t know. I'l check in the office to see what might be causing that - to me it does indeed look like some sort of UV degradation, but I wouldn't expect that to happen. It could be condensation INSIDE the casing perhaps?
yds
Thu Apr 19, 2018 11:05 am
The lens if fully exposed to the outside. I don't have it behind any covering or casing. It's placed in a hole drilled in a PVC electrical box.
6by9
Thu Apr 19, 2018 11:37 am
Inside the casing of the camera module then, behind the lens.
The sensor has no form of IP rating for outdoor use, so i wouldn't be surprised if performance degraded when exposed to the elements.
You could try taking the camera module down, removing the lens, and cleaning inside the module. Only take that approach if you are happy in doing so as you could destroy the module totally.
yds
Wed Apr 25, 2018 11:20 am
So I did remove the lens, clean behind it and in the sensor. Didn't make any difference. Guess I'll just have to get another camera. BTW - I've had a second one running for around the same amount of time, but indoors pointing outside through a window. No issues with the image on that cam. So maybe it is a UV issue, since the indoor one is protected by window glass??
mohit1
Sat Oct 12, 2019 5:47 am
Did you find any solution to this ?
Iam having similar problems
replacing camera every few months is not economical
Return to “Camera board”
