Raspiraw Usage and error when executing "camera_i2c"
Posted: Tue Feb 13, 2018 8:26 pm
by ajjsss
I get the following error when attempting to configure Raspiraw and execute camera_i2c on my Raspberry Pi 3.
Not sure how to fix this.
buf: not found
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
Re: Raspiraw Usage and error when executing "camera_i2c"
Posted: Wed Feb 14, 2018 8:30 am
by HermannSW
Seems you missed the steps under "Prepare" here, please try:
viewtopic.php?f=43&t=189661&p=1232058#p1218763
Posted: Wed Feb 14, 2018 7:50 pm
by ajjsss
Shouldn't I be following 6by9's instructions listed below?
raspiraw usage
do once
You have to clone the repo. Then "cd raspiraw; ./buildme". Finally add this line to your ~/.bashrc.
$ tail -1 ~/.bashrc
PATH=~/raspiraw:~/raspiraw/tools:$PATH
do once after reboot or use of raspistill/raspivid
Execute camera_i2c to make raspiraw work.
$ camera_i2c
setting GPIO for board revsion: a01041
A+, B+, and B2 all revisions - I2C 0 on GPIOs 28 & 29. GPIOs 32 & 41 for LED and power
Posted: Wed Feb 14, 2018 9:06 pm
by HermannSW
He merged the README.md changes from my fork, those instructions are from me, see history:
https://github.com/6by9/raspiraw/commit ... /README.md
And those instructions miss that you need to get /dev/i2c-0 working.
Do you see /dev/i2c-0 on your Raspberry?
If not, please follow the "Prepare" steps I pointed to.
Posted: Wed Feb 14, 2018 9:39 pm
by ajjsss
I followed your Prepare instructions and after running camera_i2c i get this response.
setting GPIO for board revsion: a22082
Raspberry Pi3
/home/pi/raspiraw/camera_i2c: 112: /home/pi/raspiraw/camera_i2c: ./rpi3-gpiovirt
buf: not found
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- 64 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Posted: Thu Feb 15, 2018 9:53 am
by 6by9
buf: not found
So that's the error.
The file is in the
raspiraw repo with the correct permissions, so something has gone wrong in transferring the files to your system.
And please note that the
https://github.com/6by9/userland/tree/rawcam branch is deprecated in favour of the having raspiraw in a seperate repo at
https://github.com/6by9/raspiraw/. The first post in
viewtopic.php?f=43&t=109137 has been updated with the revised details.
Posted: Thu Feb 15, 2018 1:18 pm
by HermannSW
@ajjsss has the correct version, see the text from README.md he cited.
I can recreate the problem he has, camera_i2c only works if executed from raspiraw directory.
Reason is the "./rpi3-gpiovirt" call:
pi@raspberrypi2B:~ $ camera_i2c
setting GPIO for board revsion: a02082
Raspberry Pi3
/home/pi/raspiraw/camera_i2c: 112: /home/pi/raspiraw/camera_i2c: ./rpi3-gpiovirtbuf: not found
And working:
pi@raspberrypi2B:~ $ cd raspiraw
pi@raspberrypi2B:~/raspiraw $ camera_i2c
Raspberry Pi3
Set state of 133 to 1
10: 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Posted: Thu Feb 15, 2018 8:22 pm
by ajjsss
That was the issue. Thanks you for the quick response.
Posted: Thu Feb 15, 2018 8:37 pm
by HermannSW
ajjsss wrote: ↑Thu Feb 15, 2018 8:22 pm
If you have a v1 camera as well, you might want to take 350fps or 665fps videos with raspiraw like in this thread:
viewtopic.php?f=43&t=201568
With v2 camera ...
... you can capture with normal raspivid 800x760 at 120fps!
viewtopic.php?t=201728#p1256653
... you can capture 640x480 at 240fps with raspiraw ("tools/640x480 2500 240"):
viewtopic.php?f=43&t=109137&start=375#p1263896
... you can capture 640x480 at 180fps with modified raspivid:
viewtopic.php?f=43&t=204775
Posted: Fri Feb 16, 2018 1:51 pm
by ajjsss
Can Raspiraw display video on the screen without storing the video like you can with Raspivid? If so, what is an example command line statement to do this?
Posted: Fri Feb 16, 2018 1:59 pm
by 6by9
ajjsss wrote: ↑Fri Feb 16, 2018 1:51 pm
Don't specifiy an output file (ie omit "-o <filename>") and it'll do a crude job at rendering the stream to the screen. You have no AE or AWB, so the pictures will be off.
Posted: Fri Feb 16, 2018 3:27 pm
by ajjsss
Using Raspivid and this command line statement (raspivid -w 640 -h 480 -fps 90 -t 0000 -p 0,0,640,480) I can display a 640x480 image on my monitor and also control the size and position of the image on my monitor. What would a comparable Raspiraw command line statement look like?
Posted: Fri Feb 16, 2018 4:08 pm
by 6by9
(a) You have no choice over scaling with raspiraw. It is designed to get the image data off the sensor for your own purposes, not as a general purpose camera stack. The only scaling that will get done is if the input image is too high a resolution for the display engine, in which case it divides the width & height by 2 in the hope that is reasonable (it probably ought to do that repeatedly)
(b) You currently can't specify a display window with raspiraw, mainly as it isn't intended for general viewing of the images. Feel free to pull the required code from RaspiVid and submit a PR for raspiraw (You want the CommandPreview handling from
https://github.com/raspberrypi/userland ... iPreview.c, and then setting MMAL_DISPLAYREGION_T on the render component)
Posted: Fri Mar 02, 2018 2:22 pm
by ajjsss
Where would I find a list of the command line options for both raspiraw and raspi_tc358743?
Posted: Fri Mar 02, 2018 2:49 pm
by 6by9
ajjsss wrote: ↑Fri Mar 02, 2018 2:22 pm
pi@raspberrypi:~/raspiraw $ ./raspiraw --help
-?, --help : This help information
-md, --mode : Set sensor mode <mode>
-hf, --hflip : Set horizontal flip
-vf, --vflip : Set vertical flip
-e, --ss : Set the sensor exposure time (not calibrated units)
-g, --gain : Set the sensor gain code (not calibrated units)
-o, --output : Set the output filename
-hd, --header : Write the BRCM header to the output file
-t, --timeout : Time (in ms) before shutting down (if not specified, set to 5s)
-sr, --saverate : Save every Nth frame
-b, --bitdepth : Set output raw bit depth (8, 10, 12 or 16, if not specified, set to sensor native)
-c, --cameranum : Set camera number to use (0=CAM0, 1=CAM1).
-eus, --expus : Set the sensor exposure time in micro seconds.
-y, --i2c : Set the I2C bus to use.
-awbg, --awbgains : Set the AWB gains to use.
-r, --regs : Change (current mode) regs
-hi, --hinc : Set horizontal odd/even inc reg
-vi, --vinc : Set vertical odd/even inc reg
-f, --fps : Set framerate regs
-w, --width : Set current mode width
-h, --height : Set current mode height
-lt, --left : Set current mode left
-tp, --top : Set current mode top
-hd0, --header0 : Sets filename to write the BRCM header to
-hdg, --headerg : Sets filename to write the .pgm header to
-ts, --tstamps : Sets filename to write timestamps to
-emp, --empty : Write empty output files
https://github.com/6by9/raspiraw/ gives extra descriptions of the options.
"raspi_tc358743 --help" should also apply, but I haven't run it for a while and don't have a convinient binary for it.
